2wd shifter indicator overlay
My shifter indicator lens was all busted up and cracked so I made a template and made an overlay to fit over the indicator lens. It turned out pretty decent and I figured I'd share it in case anyone else wanted to use it. I still plan on replacing the whole bezel but this will do till then. The white parts on the overlay need to be cut out and will line up with the clear parts to see the orange indicator. It's possible the D indicator may not line up right since mine was completely missing, but it should be close. I don't know how close this would be to working on a 4wd since I don't have access to one.
As you can see from the picture, when I cutout the white areas, it left some white showing which should easily be covered up by a black sharpie.
punks_is_4x4
02-26-2016 04:29 PM
Dale Johnston
11
10-31-2015 10:22 PM
Cycles
09-29-2015 06:37 AM
