2002 4Runner worn rear wheel bearing
Old 09-13-2007, 12:38 AM
Adam F's Avatar
Originally Posted by easttntoy
It's only 8 nuts to get both axle assemblies off.
You make it sound too easy. Don't forget that you also have to remove the parking brake cable, and undo the brake lines, and then bleed the brakes afterwards.
Old 09-13-2007, 06:06 AM
GSGALLANT's Avatar
Originally Posted by Adam F
It sure does. One pinion bearing, and 2 carrier bearings. If these bearings go, they can make a lot of noise.
Close... but the 3rd member actually has two pinion bearings and two carrier bearings.
Old 09-13-2007, 03:42 PM
easttntoy's Avatar
True, but my 9 year old cousin could do that. All in all it's an easy job. Mine has abs and the abs ring is more expensive than the bearings so I just took it to the machine shop to avoid breaking it. I couldn't imagine paying someone to take the axle assemblies out for me. That's rediculous.
Old 09-15-2007, 01:54 PM
RunnerUp's Avatar
and that is why i love my rear disc brake conversion... 4 bolts a side, just moved the caliper to the side and didnt have to bleed them or remove my non existent parking brake cable!
and yeah, my little 10 year old cousin could do this job drunk....
TNRunner88
07-01-2015 08:00 PM
Mr.Black
06-21-2015 10:17 AM
AustinTaco
06-21-2015 09:54 AM
dlotoy4runner
7
07-03-2002 03:42 AM
Quick Reply: 2002 4Runner worn rear wheel bearing
