1997 runner gas tank only holds 15 gallons???
Old 03-02-2006, 05:31 PM
werdwerd's Avatar
I think its supposed to be a 18.5 gallon tank but everytime i fill up on empty i get around 15 gallons in. when the light comes on how much gas is left?
I am getting around 200 miles per 15 gallons, is that average for stock? thanks
Old 03-02-2006, 05:44 PM
PatHLC128's Avatar
ive got a 02 4runner and i had a similar problem at first, then i noticed that different gas pumps allowed different amounts of fuel in for some reason. i have to keep pumping even after it quits, that way it moves the needle up way past the full line. my light usually goes on when i have about 2 gallons left i take it cuz when i do that i get about 16.5 from the pump.
Old 03-02-2006, 05:54 PM
FUZION's Avatar
i think it has an 18 gallon tank, i usually put in about 16.5 gallons when i fill up. i keep going after it clicks
Old 03-02-2006, 06:06 PM
Runner003's Avatar
I get anywhere 280 300 hwy, 200 220 City, one the light comes on it take 15 gallons The most I've put in is 16.5 gallons. Stock 99 4x4 4 runner 3.4. I still in the middle of averageing out the True flow kit and deck plate mod... always check the tire pressure and air filter... D-
Old 03-02-2006, 06:28 PM
shazaam's Avatar
If I run it to almost empty I can get 17.4-17.5 gallons in there
Old 03-02-2006, 07:03 PM
4RUNN!N's Avatar
When I ran out of gas completely, I barely rolled into the gas station (good thing I didn't have to push), it filled in a total of 17.1 gallons. I think the rest is at the way bottom of the 18.5 gallon tank.
Old 03-02-2006, 07:17 PM
marko3xl3's Avatar
On a "normal" schedule, I refill at around 220 miles, which equates to about 15MPG (80% city, 20% highway). If I feel like worrying every mile, I'll wait till 240-250, which will fill about 16.5 gallons into my tank. I am guessing I could run it till 270-280 (which is basically running it dry) and then fill about 18 gallons in there? I am also guessing that if you run it dry and fill it up so that the gas tops out of the pipe, it'll measure about 18.5. I could be wrong tho
Old 03-03-2006, 03:06 AM
8422r4Runner's Avatar
I'm talking about my 1997 Camry at this point. It has a 18.5 gallon tank, the idiot light comes on at 15 gallons. The reason is the gas in the tank acts as a cooler for the pump. When it runs down low, there is no gas on the pump to keep it cool, when they get hot they fail. So I think it is Toyota's way of protecting ourselfs from ourselfs not filling up till it says it's empty.
Also in my book it says Not to keep filling after the pump clicks off. There is a float like system in the tank, over filling the tank raises the float too high and in time will make your gas gauage read wrong.
Old 03-03-2006, 05:20 AM
Cape yota's Avatar
When i fill my tank after the gas light comes on, I usually put between 13 and 15 gallons in. If you're only getting 200mi/15gal thats 13.33 mpg, I typically get more than that (currently around 16 with winter gas) but you might just have a heavy foot. There are a number of reasons for not topping of the tank. When you top off the tank after it clicks, some of the fuel is sucked into the vapor recovery system. So you're paying for gas that doesn't go into your tank. I was also told in the service dept at the stealership that topping off the tank can cause your catalytic converters to fail. And besides, if you're paying at the pump with a card, it doesn't make sense to top it off to try and round it to the nearest dollar.
Old 03-03-2006, 05:48 AM
lee
lee's Avatar
i get about 210-220 miles per tank (thats gaslight on to gaslight on)... all due to my lead foot
Old 03-03-2006, 06:02 AM
98runn'n's Avatar
I've been getting about 240 miles per tank, and thats also when the light turns on. When I go to the pump I can only put about 14.7 gallons in, which made me think I had a 15 gallon tank too. But, apparently it is 18.5; where is the other 3.5 gallons at the pump?
Old 03-03-2006, 06:08 AM
lee
lee's Avatar
the light goes on prematurely to give you time and distance to get to a pump
if you figure most ppl avg about 15-16 mpgs, that gives people about 50 miles to get to a pump.
Old 03-03-2006, 06:09 AM
Road Head's Avatar
Desiging an SUV with a range of under 250 miles is stupid in my opinion. They should have put a larger tank in.
Old 03-03-2006, 08:33 AM
X-AWDriver's Avatar
I get about the same as Lee does since I like acceleration up to speed and that's what hurts. When I feel I've driven long enough with the fuel light on I usually only can fill up with about 15 gallons but it's better to have a fuel guage read prematurely than late. The most I've ever squeezed in the tank is 16.1 gallons.
Old 03-03-2006, 09:59 AM
Deathmage's Avatar
we have a 3 gallon reserve tank. When the gas light comes on, then it taps into the reserve. So when you fill up, you're only filling 15. also, you can't put 18 gallons in an 18 gallon tank, only about 17.8 or so, when the other .2 being a 'buffer', if you will.
Old 03-03-2006, 10:09 AM
X-AWDriver's Avatar
Actually I don't think you can use the the last gallon since i don't know anybody who's filled up with 17 gallons unless you fill the filler neck also.
Old 03-03-2006, 10:27 AM
4RUNN!N's Avatar
I log my gas mileage and the average miles I get from both city and highway drivg mixed, I usually get about 230-250 a tank before filling up.
Old 03-03-2006, 11:57 AM
X-AWDriver's Avatar
I see all these mileage results from 3rd gens and I have a hard time believing 2nd gen owners claim over 300 from an engine alot of people are lucky to see 16mpg in stock trim.
Old 03-03-2006, 01:48 PM
bdeakin's Avatar
I don't know what I'm doing right, but my '97 gets 20mpg like clock work. I only burn half the tank between fillups so as to keep a 8 gallon reserve :-)
Old 03-03-2006, 03:31 PM
outrages112's Avatar
before winter gas i was getting 20mpg now i get about 15 or so. i just did a tune up, well i still have to replace the front o2 because the last ahole that put it on seemed to have lost the nuts and put beeds of weld on the studs
Quick Reply: 1997 runner gas tank only holds 15 gallons???
