1996 4Runner Straight Axle Conversion Web Cam - March 15, 2006
#82
It's it for today, frame is 100% clean, Motor mounts closed back up.
Tomorrow is either plate the frame or front and rear leaf hangers.
I'll decide what I feel like doing first in the morning. Probably spring hangers though. Maybe both.
The Hi-Lift is there just to make me feel butter, it does creep mout out a bit sitting under there.
#83
Originally Posted by sschaefer3
Every 5 min. Well I know why everyone is pulling apart axles with the longer Old Man Emu front shocks.
Droop of the arms on a 100% stock TRD Tacoma with the longer TRD shocks is 15 degrees. Droop on this 4RUnner which has the limiting straps set more conservative that I did on mine is at 24 degrees.
Well DUH. That too much droop. I would say 20 max, if Toyota's engineers went 15 on the TRD and I would imagine the stock 4Runner shocks go 10 degrees.
IFS does not kill parts, too much droop does. It's always fun to test data on these projects.
#84
Nice pants honky!
We had to teach Steve the pail trick.
Keep hammering down. The Hi-Lift is good piece of mind, it is spooky, especially when the ears are plugged and the eyes are covered.
#86
It must feel quite nice to have just the frame rails there w/o all the IFS stuff crowding up the wheel wells.
Its like starting off on a clean slate!
You just have to setup the steering, leafs, shocks and bolting up the axle, right? (not "JUST", but, yeah...)
#88
Now it's just re-build it. Which will take time as most of it is custom made. Steering shaft Stubbs pre-made & FJ box on hand.
One day at a time. Placeing the main eyes without the Cheeseburger will be a challege. Hopefully Matt is up to it.
#89
is there a reason you didn't want to refresh the camera more? say 20 seconds or so? just curious, i get kind of antsy watching this thing. plus i'd like to see more of what's going on. just my $0.02.
looks like all is going well so far!
#91
On my SAS the ISP shut us down. I'll try a 1 minute refesh and see how it goes.
I had to re-setup on the shop computer as today I will build and install the front hanger.
Ok, I'll set it to 1 min.
Back at it for today.
#97
I'm drilling 1" holes through 1" thick stock on the drill press off to the left.
One more to go.
One more to go.
#100
I think Im going to setup a webcam of me, in my underwear ,watching Steve work with those big shafts of steel.
Stupid question, but, you're getting paid for this right? You could probably make a pretty penny doing this ... think you could do like 1 straight axle conversion a month and have tons of beer money!
