1994 4X4..What grease to use on rotor assembly
1 Post
Can I use a multipurpose grease while I change the rotors on my truck? Do I need a special grease? I have the StaLube grease that comes is a black canister. It says it can be used as a bearing grease, but also states not to mix different base greases. I just replaced my calipers and in the process of reassembly. Asking for your advise.
1 Post
Thanks Yamarocket630,
Luckily the Stalube brand grease was extreme pressure. Got lucky. Finally got everything back together. The brake fluid connection to the caliper was a real pain in the ass to get back together. A tip for you that I learned today. Autozone wanted to charge me $40 for the caliper and $40 core charge. No problem right as long as I return the core. However, turns out that they charge tax on $80. When I return the part, I don't get the tax money difference back. So, I took my old calipers to Autozone at the same time I purchased the new calipers. Essentially, they only charged me tax on the new calipers.
Thanks for the heads up.
