04 Tacoma 2.4L Rear End Ratio
Old 04-07-2006, 04:01 PM
ttus's Avatar
Isn't there a "Tag" on the rear housing, saying the gear ratio?
I read the post about turning the tire and counting the drive shaft turns.
Thanks
Old 04-07-2006, 06:01 PM
Elton's Avatar
nope you have to look at the door tag im pretty sure it is ether 4:10s or 4:11s
Old 04-08-2006, 05:46 AM
ttus's Avatar
Thanks for the reply.
Where do I find the Info, in regard to ratio from the door
sticker? What part of the sticker tells you the ratio?
Thanks
Old 04-08-2006, 06:54 AM
EnolaGaia's Avatar
For 2.4L (2WD, non-PreRunner) Tacomas (both Regular and Xtra Cabs):
- 3.58:1 (manual)
- 3.73:1 (automatic)
Old 04-08-2006, 02:02 PM
ttus's Avatar
EnolaGala, Thanks for that info.
Can you explain where and how to find that on the door sticker
code? Jusy for my own info, to learn about my truck.
Thanks
Old 04-08-2006, 02:39 PM
EnolaGaia's Avatar
You're welcome.... That info I pulled off a handy 2004 Toyota factory brochure.
Check this axle / gear site:
http://www.brian894x4.com/Gearratiosanddiffs.html
... for info on finding Toyota truck axle codes and interpreting them.
Old 04-08-2006, 04:00 PM
Elton's Avatar
you have a 2wd you didint say so i thought you had a 4wd sorry
Old 04-10-2006, 04:27 PM
ttus's Avatar
EnolaGaia
I have a 2 wheel drive, 2.4 L 4 Cyl.,Auto, XtraCab.
I got my info from the door sticker, but it doesn't jive
with the info on that site.
This is my info:
RZN150L
CRPDKAB
C/TR3P1
FB 10
That is it ??
Thanks
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
Daneums
08-20-2015 05:36 AM
TokyoD23
07-12-2015 06:01 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 04 Tacoma 2.4L Rear End Ratio
