01 Leaning Runner
Old 11-07-2005, 10:16 AM
Hayride's Avatar
01 Leaning Runner
I've got an 01 Runner SR5 Sport that I bought with 60K on it back in Feb. It was leaning a little to the left so I replaced the stock springs and shocks with OME goods. Love the slight hieght increase and feel, but the rig is still leaning to the left. I took it to the place I bought it, Portsmouth Toyota in NH, no problems found. I moved to California a couple months ago and took it to a Yoda dealer out here, no problems found, other than the lower ball joint recall they performed. I'd say it's 3/4 to 1in lower on the left looking at it from the front or behind and everywhere I've been says the suspension is fine. Any Ideas? I've never seen if it leans more with me in it, always have looked at it empty. I drive by myself most of the time but that shouldn't matter given that right after the old man emu parts were installed it still leaned. Any guesses appreciated because this simple little problem is driving me nuts.
Old 11-07-2005, 10:26 AM
rimpainter.com's Avatar
Can you post a pic?
Old 11-07-2005, 10:42 AM
Hayride's Avatar
I'll get a pic on here, will try for tomorrow the 8th.
Old 11-07-2005, 10:59 AM
Albuquerque Jim's Avatar
It the lean even front to rear? I'd try to switch out the rear springs from right to left.
Old 11-08-2005, 07:29 AM
Hayride's Avatar
Can't find my digi cam. Once I do I'll get a pic or two on here. I don't see how a pic will help anyhow, will just show that it's leaning. Still, I'll get one when I find the cam. Just had something from an overpass bust my window real good, oh joy. Any advice on 265/70/16's like I have right now vs. 265/75/16's, as I'll need tires in a couple months, probably BFGoodrich All Terrain T/A's.
Old 11-08-2005, 07:48 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
There have been previous threads regarding a front height difference due to reversing one of the bottom spring plates (don't recall the terminology) on one of the front shocks. The dealership had done that to mine and it leaned was about 1" or so taller on the one side.
EDIT:
Check this: https://www.yotatech.com/forums/show...t=shock+spring
Old 11-08-2005, 01:59 PM
Hayride's Avatar
The seats look good, unfortunately.
Old 11-10-2005, 08:40 AM
Hayride's Avatar
Pics
Maybe it leans because it's so cool...?
Old 11-10-2005, 12:35 PM
Hayride's Avatar
attempt at pics
pics attached.
Attached Thumbnails 01 Leaning Runner-100_1328.jpg   01 Leaning Runner-100_1344.jpg
Old 11-10-2005, 03:24 PM
98LimitedCustomized's Avatar
I hate to say it but mine kinda looks the same, and I have the same setup.
Old 11-10-2005, 03:34 PM
SnoViking's Avatar
i just installed OME 891s last night and i put the taller spring on the drivers side... and the truck is taller on the drivers side now.. but about an inch... so i dont know either
Old 11-11-2005, 09:01 AM
Hayride's Avatar
I'm going to look into the body mounts. You would'nt think at 80K they would be bad but....
Old 11-11-2005, 01:39 PM
Hayride's Avatar
[QUOTE=98LimitedCustomized]I hate to say it but mine kinda looks the same, and I have the same setup.[/QUOTe
How do you like your 265/75/16's over 265/70/16's??? Are they taller by about 1/2" or so?
Old 11-11-2005, 10:25 PM
BajaRunner's Avatar
Are you sure you put the springs on the correct sides?
Old 11-12-2005, 02:21 AM
grimpy's Avatar
Try measuring the frame on the driver side and then the pass. side. If they are even, then check the body mounts.
Charecter1
11-06-2023 10:08 AM
MTLroadierunner
07-15-2015 12:58 PM
musashi86
California SoCal
07-07-2015 03:31 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 01 Leaning Runner
