RBx 1988 4Runner Build-Up Thread
Old 02-22-2017, 06:38 AM
  #1941
RBX
RBX's Avatar
Originally Posted by matmattmatthew
I'm sure you know this, there's a restaurant in Hampden called "Rocket to Venus". Also, did you get the Holy Frijoles awning after the fire?
yes, my buddy owns both establishments and the garage I'm doing the swap in.
LiveOffroad, thanks, it's slow going at the moment. Hopefully I can add coolant to the lump and crank it up this weekend.
Old 02-22-2017, 07:03 AM
  #1942
matmattmatthew's Avatar
I figured it wasn't a coincidence that there was a connection to both those places. I live just a couple miles away and every time my wife and I are on the avenue we shed a little tear when we see the Holy Frijoles building.
Once you get the shop up and running I'd be interested in talking to you guys about getting some work done on my 4runner.
Old 02-22-2017, 12:04 PM
  #1943
RBX
RBX's Avatar
Frijoles is under a major renovation from the fire. It will be open again.
Old 02-22-2017, 08:43 PM
  #1944
RAD4Runner's Avatar
Nice to have a good place to work on the trucks. and awesome story...
Originally Posted by RBX
building a rocket ship to Venus back in 1928......
My buddies restaurant is named Rocket To Venus www.rockettovenus.com because he owns the house and garage...
Cheers!
Old 02-23-2017, 01:41 PM
  #1945
RBX
RBX's Avatar
^^^ agreed, just wish it was in my backyard, I'd have much more done by now.
Old 02-26-2017, 06:01 AM
  #1946
RBX
RBX's Avatar
No Start Weekend
Just didn't have enough time to get her cranked since I still need to ground the harness to the cradle and retrace the harness to make sure everything is plugged in correctly. Also need to rig up a fuel tank, but that is just some hose and a container since no in-tank pump. A few pictures of the spaghetti.
Old 03-08-2017, 04:03 AM
  #1947
RBX
RBX's Avatar
1KD-FTV First Start
Its Alive!
4Runner 1KD first start - YouTube
Old 04-06-2017, 06:55 PM
  #1948
likkleBIT's Avatar
That is simply beautiful! Congrats!!!! Steady she goes!
Old 04-06-2017, 06:58 PM
  #1949
RBX
RBX's Avatar
Thanks, haven't finished reading your update yet, but you will be enjoying the new engine soon!
Old 04-27-2017, 06:34 PM
  #1950
RBX
RBX's Avatar
Not that I'm that organized in my thread posts anyhow, but this thread is about to go all over the place while I finish the wiring harness revamp. I'm bored so I am going forward with some other small projects that are mostly independent of the engine swap, except this one.....cruise control. Cruise is important for me because I don't trailer my rig, I've spent over 9hrs straight in the driver's seat, and cruise is a necessity.
My MK6 Hilux engine was a DLX, so no dimmer(rheostat), locker(s), fog lights or cruise control.
Cruise control on most ODB2 Toyotas use the same switch stalk for cruise set and reset, lucky for me throttle by wire Toyotas only require the switch stalk and an LED in the cluster....
Cruise stalk from a local yard...check! $18
SMD 1206 LED in the mail....
Old 04-27-2017, 07:50 PM
  #1951
space-junk's Avatar
wander where you want, we will follow along happily.
cruise is where its at! every year i do a 15+ hour trip to the PNW and not having cruise control is the worst.
Old 04-28-2017, 05:06 AM
  #1952
magnet18's Avatar
excited to see how the cruise control swap goes, i plan to put cruise in mine soon
Old 04-28-2017, 11:29 AM
  #1953
RBX
RBX's Avatar
1KD High-Idle mod
So along with cruise, I want to install a high-idle knob/switch/attenuator/potentiometer for winching, warm-up or crawling.
Needs to be 2-pole switch and capture the VPA1 and VPA2 wires on the accelerator pedal.
Like this, but actually finished and only one potentiometer.
Wiring, and test data
Old 05-22-2017, 11:56 AM
  #1954
JBurt's Avatar
Somehow I stopped getting updates from yotatech. This is awesome. Glad it got started up!
Old 05-23-2017, 09:36 AM
  #1955
RBX
RBX's Avatar
No real update as I am sorting and refining the wire harness. I did install the new LEDs on the Cluster PCB, but have not tested them as of yet.
Cruise will take a few more wires to connect, but should be easy while the harness is being dissected.
Old 05-25-2017, 03:18 AM
  #1956
likkleBIT's Avatar
Keep on chugging!
Old 06-22-2017, 03:53 AM
  #1957
RBX
RBX's Avatar
Want To Buy Dual Adapter
Want to buy Dual Case Adapter
I may end up buying a new dual case adapter for this build, but I'd entertain a used setup. I already have the cases but need an adapter to double them up. Currently both cases are 21-spline.
let me know what you have and where you are located.
Old 06-26-2017, 06:53 AM
  #1958
RBX
RBX's Avatar
No real update, working on some hydroboost brake conversion at the moment.
Old 08-17-2017, 05:21 AM
  #1959
RBX
RBX's Avatar
I need to order my main and connecting rod bearings (1kd-FTV) soon before I install the engine. I have the part numbers for the bearings, but do i need to order OEM, or are there reputable companies I could get the same bearing from without the Toyota tariff?
Thanks for the help
Old 04-09-2019, 05:46 AM
  #1960
RBX
RBX's Avatar
New updates on the way, Hydroboost is in and bled, still need to road test. Also, working on getting new photos posted.
Quick Reply: RBx 1988 4Runner Build-Up Thread
