Head Gasket job 90 4 runner 3.0 vze 6 point head bolts size?
Old Jul 19, 2015 | 05:54 PM
kgcwb44's Avatar
Does anyone on this planet know what the size is for the 6 point bolt on the cylinder head?.... doing a head gasket job got my arp studs on, nuts torqued, and go to find the 6 point and have no clue where it is... I've scoured the internet and all kinds of repair, maint, and o/h manuals to find it and i am at a loss... some help would be greatly appreciated thanks. I could just guess but i'd rather not tear this thing apart again if i guess wrong, just trying to make sure i do everything the right way... again thanks
Old Feb 28, 2016 | 04:39 AM
Desertrat013's Avatar
While I maybe late with this reply, I am still going to ask the obvious. What are you asking for the size of? the way the question is worded it is truly a "how long is a piece of string?" question. are you asking what size socket fits the 6-point head bolts? are you asking what size threads are on the end of the 6-point head bolts? or are you asking what size socket fit the nuts for the studs, you got from arp?
Old Feb 28, 2016 | 05:00 AM
MudHippy's Avatar
Well...if you've ever done a 3VZ-E head gasket job the question is a simple one. And the pic shows the empty bolt hole as well.
Not that it likely matters at this point. But the answer is M10 x 35mm x 1.25(w/ a 3mm thick washer). Maybe someone else will need it at some point.
Old Jun 30, 2020 | 04:59 AM
Akira's Avatar
Thanks MudHippy! Just what I was looking for!
Old Jan 29, 2023 | 10:02 AM
uvacitas's Avatar
Battery tray part # for Group 24 battery?
My 1990 4x4 and my 1991 RV cab & chassis (both 3VZE's) both have the 55D23 plastic battery tray, which is a bit too short for a Group 24 battery. Does anyone know the part number for the tray that will hold a Group 24 battery in the stock right side battery sopport? I have lost a group 24 battery to each, one while wheeling and had the battery shift into the PS pulley and the other because the person I bought the RV from used a wood shim spacer to secure the battery which loosened and suffered a similar fate as the first. Thanks!
castone001
Nov 24, 2010 11:05 AM
hairbear65
Feb 17, 2010 07:40 AM
tonetti
Feb 16, 2010 07:17 PM
Skinsfan6
May 17, 2009 07:02 PM
hirsche23
Jun 26, 2006 11:53 AM
