Cold start valve does not shut off
Old 09-27-2016, 07:09 PM
Need help 86 runner's Avatar
1st post. I am trying to work ok a 1986 22re. When cold start injector is unplugged truck runs fine when I plug the cold start injector in the truck stalls. With the engine running I checked the connector going to the cold start injector and with a test light found that there was still signal. Should the signal not be there when the truck is running? Is this an ecu issue.
Old 09-28-2016, 04:38 AM
92ehatch's Avatar
This should be in the tech section but i believe there is a temp sensor that controls that and when the engine warms up should shut power down to the cold start injector.
https://www.google.com/url?sa=t&sour...0EqgD_4JOPOAyw
Old 09-28-2016, 06:11 AM
Thank you, Yes I have moved the question to the Tech section.
RustBucket
09-02-2016 02:52 PM
Ruger2011
08-03-2016 02:07 AM
10ac
07-25-2016 07:44 PM
Robert Otte
07-17-2016 05:38 PM
Quick Reply: Cold start valve does not shut off
