92 2WD LB Fuel Leak
92 2WD LB Fuel Leak
I have a fuel leak (it squirts out when the pump is on) at the top of my tank, and i need to replace it. From what i can see it is a corroded fitting on part #13 pictured below.
I'm just trying to get some prices so i can replace it. Anyone have a part number for this? Looks like only OEM is available for $168.00.
You try NAPA, used ones on ebay are around your new price, maybe someone on here who's out west or south has an extra one to sell, if your going to keep truck a while just get a new one, if mine goes bad, I'll get a new one. While your doing it check your fuel pump filter sock and check tank inside for rust :} Best way to changer it is to lift up that side of the bed and will not tear up fuel lines if there also very corroded and not fun wrestling that tank out from underneath especially on a 2WD, easier on 4WD :}
