broskyo's 1985 4Runner Build-Up Thread
Ok so the 4runner has been have trouble idling after its been run for about 30 seconds to a minute when its cold, and it wont idle at all when its warm. It also just starting bucking a couple days ago. I checked a the vacuum line they were all good so I check where then go into the throttle body and they were plugged with black gunk. After that I took the throttle body off and cleaned all the clogged parts and the rest, but there was a really thick layer of the black gunk in the whole body so I just made sure all the ports were cleared out and the put it all back together and now it wont run at all. If I can get it to start I have the keep the revs high or it will start backfiring or missing and die. I put all the vacuum lines back on and I'm almost positive there all in the right place.
So any ideas????
So any ideas????
#26
The 4runner is still not running I've done the tps and afm tests on 4crawler. I was wondering if anyone knows if the AFM is supposed to make a loud ticking noise(like the air flow gate is opening and closing really fast) when the motor is cranking and almost firing up?
#27
I just took my front axle apart to put my 5.29 third in and I got everything put back together but the axle inst sticking out enough to get the snap ring on.
#28
sometimes it gets pushed in a little bit, you should be able to pull it out enough to get the ring on, if you cant pull it out enough then you put it back together wrong.
06-01-2021 01:51 PM
jon.r
07-11-2015 03:34 PM
