83crawler's 1983 Pickup Build-Up Thread
#41
well once i start working again im going to get all this stuff done
1.30spline longs, with hub gears full marlin crawler rebuild, arp knuckle studs and arp hub studs ifs hub with fj60 rotors and v6 calipers
2. new 529s detriot up front and spool in back
3.duals with mc07 adapter and chromo 4.7s with long field output with front range off road crossmember, get some driveline tech drives front and rear, w56 and marlincrawler 1600 pound clutch
4put on my ifs rear axle with disk brakes
5. 2nd gen rears up front mixed with 2wd rears and boomerang shackles 63s in back with frenched spring hanger and shackle on back of the frame
6. 4xinnovations interior cage
7.get my motor rebuilt.
8.40in mtr with 17in dimond racing wheels with 2 or 2.5 backspace
9. 2nd gen 4runner buck seats
10. fix my heater clean up all the wiring only get the wires i need.
11. put stereo in and some speakers and hopefully a sub
12. fix rust hole in the floor.
and thats it for now! i hope
#46
Thanks! it runs and drives good, but needs lots of little work. gotta service the axles build bumpers and such. only thing i've done to it, got the tires and wheels and put a spartan locker in the rear couple weeks ago. plan to dd it someday lol. wish you were closer, so we could wheel
#47
#48
all the way in south carolina! only got one place to legally wheel thats about 30 minutes from me, a place called Gulches. its ok. its only like 82 acres of short trails but its always fun to go
#49
83 crawler you said you live in milwaukie? I am picking up a 79 on monday and i live in milwaukie oregon, maybe sometime after i get situated in my truck we could go wheeling after yours is done?
#54
http://www.ebay.com/itm/4-cylinders-...#ht_2682wt_840
http://www.ebay.com/itm/LPG-GPL-auto...4#ht_879wt_700
http://www.ebay.com/itm/DUAL-FUEL-PR...#ht_1201wt_700
i'll dig out more info later. one of the vendors (the first one, i think) gave me the installation instructions. basically the same setup as now, but instead of the intake adapter, there's a series of injectors that feed the intake plenum
they've actually come down in price a whole bunch
#56
once i get a better income (aka a job) i'd like to do either this or a diesel swap (or get another truck and do both)
edit- here's the email chain with a bunch of info on the kit:
Hi Ian,
the converter temperature sensor is fitted to the LPg pressure reducer.
The vapour sensor is mounted on teh injector rail.
The multivalve is the valve block fitted to the tank. This includes the level float, filler entry, filling stop valve and outlet valve with electronic shut off.
The cut intector wiring will be for 4 cylinders only. Bosch fittings are offered as an extra but you will want the solder in ones that come as standard. That makes the job neater and Jap plugs vary and often do not fit. I very rarly use plug in looms.
The UK filler system uses the bayonet system. I'm sure the US normaly uses the ACME system - I can supply an ACME filler as they are also used in parts of Europe.
Do you want some photo's showing the layout of the system?
Regards
Dai
To: dai@classicswede.com
Sent: Wednesday, 9 March, 2011 14:37:08 GMT +00:00 GMT Britain, Ireland, Portugal
Subject: Re: LPG conversion kit
Thanks Dai,
Those helped. Just a few questions about the diagram on page 17-33:
-Where is the "converter temperature sensor"?
-Connections 6 and 7 are left disconnected, but I'm assuming they can be connected for read-out information on a PC? How/where would they connect?
-Where is the "multivalve"?
-For the "cut injector wiring", does the kit come with it for 4 cylinder engines? And what style termination connector does it have for the injectors?
-Are UK and US propane fittings the same? Or do I need an adapter? I'm not too familiar with other propane systems.
Sorry for all the questions, but I want to make an informed decision. So far, I'm understanding this system much more than before.
--Ian
Subject: LPG conversion kit
To: irab88@yahoo.com
Date: Wednesday, March 9, 2011, 6:50 AM
Hi Ian,
the tank system is slightly differnt for the USA so you realy only need to look at the front end instructions. The hardest part is the wiring.
Enclosed are the wiring diagrams.
Regards
Dai
Regards
Dai
Thanks Dai,
--Ian
Hi Ian,
Regards
Dai
