82 Toyota -51 Willys Hybrid Pickup
AXLE guru's challenge
Help! - I'm trying to locate info needed for my project:
Rear axle, 65" wms-wms, 47.5" spring perch center-center, 4:11 gears, center pumpkin, 6-lug Toyota pattern.
Note: I don't need/want an extreme-duty axle as this truck will be a daily driver, back-road cruiser. Hoping someone can direct me to an axle brand/model that fits these specs. Moving the perches is ok, just trying to avoid re-gearing/shortening, etc....thanks.
Possible axles - what ratio's were available
I agree - any idea what ratios were available? Another possibility looks like the Landcruiser...found the info below, it's just not complete enough.
Toyota Axle Widths: (top)
(all widths are measured wms-wms, wms=wheel mounting surface)
'79-85 front axle~ 55.5", rear axle~ 55"
'86-95 front IFS~ 59", rear axle~ 58.5"
Tacoma 4x4, '96-up 4runner front IFS~ ???, rear axle- 60"
T100 front IFS~ 65", rear axle~ 66.75"
Tundra front/rear~ ??
'90-97 Landcruiser FJ-80/FZJ-80 front axle~ 63.5"
* Another tidbit: 2wd 4runners, Tacoma PreRunners, T100's, and Tundra's use 6-lug wheels- same as the 4x4's
(the other 2wd's use 5-lug)
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
