FS[WestCanada]: Pre 84 stuff
lledwood, got your message earlier. Can you give me a price on the one of the 2 grille emblems (whichever is the better one from the 82-83 grilles)?
I'm also interested in the black door pull handles and a rear view mirror if they are in decent shape.
Shipping would be to 21804
Thanks!
Thanks!
Hey bud looking for fusable link from a 79 or 1980. I have a picture of a butchered one for reference. It would have only been on a truck with center pod ammeter.
also need the 6 pin plug that goes to either the alternator sub harness or wiper motor.
interested in those black door cards
Battery hold down bar, jhook, and plastic tray
that fusable link will have 2 or three green plugs on it that are not pictured.
Lemme know!
Lemme know!
I saw where you were selling interior as a whole, so never mind on the door cards.
if 79 or 80 doesn't have ammeter it will still have 2 fusible links I can use:
one with one plug with red wire green stripe the other with 2 plugs(white wire, and black wire with red stripe). I could use those too and make my ammeter link.
If you have the one for ammeter it will have big plug close to battery before it branches off to the links.
so everything on the positive battery terminal down to 2 green plugs.
Do you have a dizzy out of a 1979 20R? Its a 'one off' with smaller cap and rotor, but electric ignition.
Factory Antenna would be cool too.
sub harness for alternator?
accelerator pedal with rubber loop on back intact.
Steering column cover for tilt wheel (adjuster is on left side of column)
radio harness plugs, one with 3 wires the other with 2 both with blue wires I believe.
Sorry list goes on, nothing has to be perfect just useable/repairable.
Michael
Michael
msane99 - if you can't find a set of factory fusible links then let me know, I made my own from fusible link wire and I have a bunch left over.
Edit, above is not intended to steal sales, I just know how hard they are to come by. I've bought parts from lledwood and have been extremely pleased!
How much for the black
arm rests/handles
holy ˟˟˟˟˟ handles
window handles
the black trim around the cab where the door closes
and the black trim piece that goes on the bottom of the cab where the door closes
shipped to Calgary t2e6s5
also do you have front signal lights?
and sun visors?
Thanks!
arm rests/handles
holy ˟˟˟˟˟ handles
window handles
and sun visors?
Thanks!
How much for
and the black plastic trim piece that goes on the bottom of the cab where the door closes
At least I think I see some black ones in this pic
Thanks
