Domestic Swaps Chevrolet, Ford, ect
LS1 into 2nd gen 4Runner ayone?
Old 04-14-2007, 01:02 AM
  #61
blazerboy72's Avatar
Yes 2wd would be much easier. So far I have the radiator in and the top hose on, I have to remove the ac condeser to give me room for an electric fan, and I have to find/make a lower radiator hose .
Old 04-14-2007, 08:44 AM
  #62
smashmetal's Avatar
Did you use the 5.3's radiator? And where you able to get it in there with out having to cut the core support. I know that a little more room can be made if the core support is cut abit.
Old 04-14-2007, 01:15 PM
  #63
I am using the stock radiator
Old 05-07-2007, 12:00 PM
  #64
deserttoy84's Avatar
any updates?
Old 05-07-2007, 02:19 PM
  #65
No not yet. I had some unexpected bills to pay, but I have taken care of that and should be making some progress in the next few weeks.
Old 05-09-2007, 01:24 PM
  #66
I pick up the front end saturday. It is a 76 wagoneer dana 44 with flat top knuckles for $150.
Old 05-10-2007, 11:05 AM
  #67
all_terrain17's Avatar
Props dood. It's nice opening up a thread and not just seeing someone just TALKING about it, but actually DOING it.
Old 05-11-2007, 02:23 PM
  #68
I picked up the axle today. I had heard they were 58 inches wide but this one is 61.5" which is perfect for what I needed. Has anyone done a sas with a wagoneer axle and left it spring under axle? I am thinking about using 5" HD springs, for the v8, SUA and 63" chevys in the rear. I dont know if this will work or it will be level but that is what I am thinking right this second.
Old 05-18-2007, 03:38 PM
  #69
I just ordered the front springs. I ended up getting the all pro 4". Maybe by the end of th month I will have the front done so I can finalize the engine placement.
Old 05-19-2007, 09:15 AM
  #70
SAS'dToy's Avatar
you'll need 60's and the swap has been done....I can't remember where I saw it but it's out there
Old 05-19-2007, 03:31 PM
  #71
I cant afford 60's. If I break then I will upgrade but for now I am using 44's.
Old 05-19-2007, 03:38 PM
  #72
JEDI87's Avatar
Looks good, why not switch intakes like the one in the gto and gain some clearance?
Old 05-20-2007, 12:43 AM
  #73
Because I would have to change all of the accesories and I would lose some toque.
Old 05-22-2007, 02:43 PM
  #74
I finished the spring over today. The leaf springs should be here this week but since allpro decided to add an extra $100 to my order it will be a few weeks before I can get the spring hanger kit.
Old 06-07-2007, 10:57 AM
  #75
Ordered the sky full width kit today. I should be making some progress soon.
Old 06-07-2007, 11:40 AM
  #76
amusement's Avatar
Kudos blazerboy72! Awesome work!
Old 06-23-2007, 02:22 PM
  #77
I am still waiting on parts to come in. I have ordered a set of 63" chevies, spring hangers for the front and rear, and shackles for the rear. I bought the 63's off of fullsizechevy.com for $50 shipped if anyone else is looking for some.
Old 06-25-2007, 03:51 PM
  #78
Ordered the body lift today. I couldnt find any way to clear the transmission with out one. I guess my plan for 33's just went out the window.
Old 06-27-2007, 04:07 PM
  #79
I put the body lift on today. It looks like the transmission will fit with room to spare.
Old 07-04-2007, 02:54 PM
  #80
Finally got the front axle in and the body lift on. I bolted on one of my 38's from my blazer just to see what size tires I need to be looking for. Now its time to start on the rear.
Quick Reply: LS1 into 2nd gen 4Runner ayone?
