Domestic Swaps Chevrolet, Ford, ect
4.3 swap in 1989 Pickup with IFS
Old 04-12-2012, 01:20 AM
9four4runner's Avatar
more pix man im pickin up a 4.3 and guna carb it i cant stand the wiring mess. how hard was it to wire in the cpi to get it runing and are u using the stock gauge cluster?
Old 04-13-2012, 09:48 PM
james92toy's Avatar
Wiring the cpi was easy. I used a painless harness for $300 You could use a stock harness and get rid of any wire that doesnt plug in to the motor. Everything just plugs into the stock sensors and the computer.Then you need find a few wires , brake light, key on/off , fuel pump. You need to buy a factory toyota wiring manual. Mine was about $40.00 on ebay. Most all the wires come out of two plugs on passenger side kick panel. You need the manual to tell you witch one's go where. Yes all my gauges work like stock. I drilled and tapped for a toyota temp sensor in the intake and ran a wire to the kick panel. For the oil pressure i added a "tee" fitting and used the stock chevy "for the computer" and a toyota one for the gauge and wired it to the kick panel. For the tach i used the factory tach wire for the chevy and ran it to the kick panel. I plan on doing a write up soon . But the same would could be done for any engine swap.
Any questions you can pm me so we wont clog up thatsmyYOTA89 build post.
Your motor looks good thatsmyYOTA89. These motor's are so easy to work on. Hope your having fun building it!
Old 06-03-2013, 07:48 PM
phildelfino's Avatar
any updates.
this is over a year old and I think you could post it here.
unless you got this in a different thread.
thanks.
AustinTaco
08-22-2022 10:45 AM
Ott47
06-26-2015 05:21 PM
Outsane
06-24-2015 05:52 PM
AustinTaco
06-21-2015 09:54 AM
89-4run
09-05-2002 08:15 AM
Quick Reply: 4.3 swap in 1989 Pickup with IFS
