Starter Trigger wire
14ga. Is fine
Or if you have a bunch of smaller stuff laying around you could twist it together to make a bigger gauge wire. Put one end in a vice or something and the other end in a drill and twist it tightly to achieve a "larger" gauge wire.
34, comp, directions, installation, instructions, pro, starter, starters, statarter, swap, trigger, wire, wires, wiring, working
