Evap/return line routing... major gas leak
Old 12-20-2009, 04:46 PM
TatonkaII's Avatar
I know this is posted somewhere and I remember a good picture with a diagram that someone did for the EVAP hose routing, but cant seem to find it. I think it was simply a picture of the EVAP and text done in MS Paint or something. Anyway, after many months of work/research I got my 1985 22R to 3.4 swap to start and run, but i left a line out which i think its my return.
What line is this, to my return line? its on the driver side of the engine and the line is about 6" (its the one I'm holding..) the one above it i have run to my EVAP box.
Attached Thumbnails Evap/return line routing... major gas leak-gasline.jpg
Old 12-20-2009, 06:23 PM
dntsdad's Avatar
Check the sticky above by Evoltra. There is a good diagram for the evap there.
here is for a 97 Runner if you are using that system.
Post if you need something else and I'll post it if I have it. Good Luck
Old 12-20-2009, 07:40 PM
dntsdad's Avatar
that looks like the fuel return line. trace it back and see if it goes here. If so, then that is what it is. Sorry for the blurry pic, but it should work for ya
Old 12-20-2009, 08:01 PM
TatonkaII's Avatar
ok, thanks. I just over looked it (big time) and figured it was the return line. If anyone else knows for sure I would appreciate it. I think my evap is otherwise hooked up correctly.
EDIT: That picture looks to be on the back side of the engine. I will trace it back like you said and see if that is it. However, it looks with its routed differently.
Old 12-21-2009, 07:14 AM
dntsdad's Avatar
yes, that is the back of motor but i think that the hose you are holding comes from here is why I put this shot up
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
ryerye13
07-14-2015 08:27 AM
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Evap/return line routing... major gas leak
