evap
evap
hey all im in the middle of doing a 3.4 swap and im curious if i can eliminate the evap system, there is no emissions tests here so i dont need it, but will it run right?
I'm not running any of the EVAP stuff and can't tell if there's a difference, or not, since I never drove the 3.4 prior to swapping.
If you can get a better pic of the connector, I might be able to identify it. It looks like it might be the EVAP connectors. I'd have to look at my engine, but I'm pretty sure I just left those to up near the firewall.
nope all my egr stuff is also blocked off, dont these motors have a knock sensor threaded in the side of the block? if so i dont have one
You can take it off if you'd like but like 97ltd4x4 said you'll have to deal with the CEL on. Your not really going to gain anything by removing it so I'd say leave it on.
yeah that looks good, does the fuel pressure regulator vacuum hose plug straight into the manifold or do i have to hook it up to a vsv? if so which hoses go where on the vsv?
