3.0 to 3.4 swap help
Ok well the engine and tranny are only 5 miles away. The motor with harness is 150. Also the motor and tranny one is out of a 2001tacoma. So I don't know if that's a problem? Lastly can I get the engine and tranny then just go get a complete harness and ecu out of a 2001? Or needs to be just for that engine? If that's the case then forget it. Maybe I should just build the 3.0 up.
Doing a 3.4 swap with a complete donor is a LOT less trouble in every aspect.
Just picked up an 04 2WD Taco 3.4 donor complete and an additional stand alone 3.4 engine for $500 but that was a steal. The 2nd 3.4 we will source parts but considering we are starting basically free it's a no brainer.
:wabbit2:
:wabbit2:
Another question here. I have a 1992 Toyota pickup xtra cab I'm putting that 3.4 in. I am also doing an SAS. I assuming it's easier to do that without an engine in. Should I just start the sas and lookout for a full doner seeig as I don't need it for a bit? Or get that engine and tranny. He will go to $400. And collect other parts slowly? Or last option just build what I have. The 3.0? Port and full rebuild.
#28
You're going to have to chop off the IFS while you swap the engine. The T100 oil pan won't fit in the IFS cross member if I remember it correctly.
While you're thinking....get working on taking out the 3.0 first....
You'll have to decide if you want to keep the a/c or use the 3.4 a/c. There's also cleaning up to do when you take out the 3.0
#29
Oh ok sweet thanks guys. I have the 3.0 out but without the 3.4 donor or motor and harness I don't want to pull any wires from the engine bay that needa to stay. Also with 3.4 what gears should I run? I will have 35s. I have stock 4:56 in rear. Go 4:88 or 5:29 like I had in my 4cly. Thanks
#31
#32
Ah ok I will keep the 4:56 thanks or maybe 4:88. I have a set of both. This is off topic but last question for awhile. Thanks for all the responses thus far. I just picked up today a dual transfercase setup that came out of a 1983 Toyota. I k ow the crossmember won't work but does anyone know if the transfercases and adapter will work? On my 3.0 tranny. Thanks.
#33
You'll need the v6 adapter from marlin or trail gear And those cases will go on your 3.0 tranny. I have duals on my 3.0 r150.
Also if you are going to run duals, I would surely go with the 4.56 gears. That's a good mix IMO. Decent highway speed but plenty low for off road with duals.
#34
Alright. Probably just sell the dual case setup. Any idea how much I should ask? I got the complete front axle,complet rear axle with a lockrite locker, and the duals for 600. Also all four 4" superflex springs. Just selling the duals and rear axle for money back. What should I ask for each?
#35
And finally set up to get that 2001 tacoma engine and tranny tomorrow with 135k. Doin a full rebuild. Just have to find a harness and ecu! And steering box? I don't know what the deal is on that either.
#37
Ok well still trying to find the 3.4. In the mean time doin sas. There is a local guy here that says 1200 still in vehicle. Have anything I want. Motor, harness,ecu,evap,all that and has 66000. Won't sell whole thing. Just keep lookin for full doner I guess.
