3.0 to 3.4 ?'s
Old 03-07-2010, 03:35 PM
Houston5's Avatar
3.0 to 3.4 ?'s
I am purchasing a 3.4 auto,complete harness,accessories,etc.I am missing the ecu,intake tube and box,VSVs.My question is does anyone have a pic of the VSV's or part # so i can find what i need.
Old 03-08-2010, 04:30 AM
Wavephf's Avatar
What year is the harness, just to get a better idea of what valves you need.
I think the only ones my 3.4 had was the ones on the evap canister. I used the 3.0 vsv valves for the 4x4.
Old 03-08-2010, 11:37 AM
yodathespian87's Avatar
Yeah the only VSVs I believe I am using are the 2 mounted on the EVAP canister, you can run the old 3.0 EVAP system. Check Beckinrajs thread (I spelled that wrong) You are going to need that ECU! I don't know what your plans are but you should grab that if its still available.
Old 03-08-2010, 12:24 PM
Houston5's Avatar
Thanks guys, it is a 98 3.4 going in a 89 5 speed.I found a ECU on craigslist.I didn't know that you could use the 3.0 evap system.I am still a little afraid of the wiring but there is so much info on here i think i can handle it.
Old 03-09-2010, 05:50 AM
jskijoe's Avatar
I know that Elvota has some good info on this and it was helpful for me. Pictures with callouts were hugely helpful...
https://www.yotatech.com/forums/f160...4-swap-128285/
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
sphealy
09-03-2015 07:55 PM
ashersullivan88yota
08-19-2015 06:00 PM
Valvoman
08-08-2015 03:52 PM
93toyoguy
08-02-2015 07:41 PM
Quick Reply: 3.0 to 3.4 ?'s
