Tale light out in 91 4runner
I know on my 89 the tailgate doesn't have to be down, but you're a 91 so I'm not sure. You should be able to tell by looking at where the screws are located. Usually, you can just take the lens off, and the whole reflector and light assembly comes out. Mine is like 6-8 screws on the lens.
Try this...take the rear carpet panel off, remove the metal panel, apply 12 volt power directly to the window motor and lower the window. It may be as simple as freeing up the sissor (sp) arms that raise and lower the piece of glass. Drop the gate, change your bulb (both sides) and then fix the reason the window won't move.
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
