View Poll Results: What OIL are you using?
Amsoil
71
16.40%
Redline
1.85%
Royal Purple
1.39%
Mobil 1
172
39.72%
Castrol Syntec
44
10.16%
Non-synthetic
132
30.48%
Voters: 433. You may not vote on this poll
POLL: What oil do you use??
I use whatever the dealer puts in, I believe it's Mobil 1. If I had any place to do it I'd change the oil myself, and if I had any money I'd be using full synthetic but alas, I'm poor and drive too much and live in an apartment.
Originally posted by waycan
More Questions for you guys using Amsoil. Which of the amsoil oils are you using? If I remember correctly they have at least three types. Also are you using the extended oil change intervals as they recommend. If so, do you change the filter part way through the interval?
Mike
Mobil 1 5w30 with K&N oil filter. I like the fact that I can use a 1" wrench or socket on the filter. I find it much easier in the tight space than using a filter wrench.
#25
Originally posted by Bumpin' Yota
Valvoline HiMileage 10w40
i ran amsoil 5w30 syntechic motor oil with an amsoil filter in my old taco. i changed the oil filter every six months and the oil itself every 12 months. no problems.
#26
OIL
Good ol dino. I noticed a few guys switch between synthetic brands, or atleast imply they do. This is very bad for the vehicle, you should never swtch synthetic brands once you've chosen one you should stick with it. With synthetics the way they protect essentially is the same but the detergents and compounds are so different that you shouldn't change up.
#27
#28
you guys really dont need to run synthetic in your toyotas unless you are in a pre runner going 150mph accross the dessert
you are just wasting money when you could get other cool toys for your toy
look up the designed applications for a full synthetic or even a blend synthetic oil
#30
VALVOLINE SYNTHETIC 10W-30
fram 2x filter
My other Toy is a 1980 4X4, 20R 4 speed, with 31X10.5-15's, 320,000 miles, downey headers, K&n filter at 80,000 miles, aquired truck at 38,000.
IT STILL SCREAMS! Uses oil only after sitting for 6 weeks or more.
fram 2x filter
#32
Is the Valvoline Full Synthetic just as good as Mobil 1? A mechanic told me to jut use Mobil 1 because there are too many companies that claim to be just as good. We all know Castol Full Synthetic is a waste of money.
#33
After a lot of research over 2 decades and through personal experience I've rejected Mobile 1 for motor oil mainly because Modile 1 tends to reject heat. Don't get me wrong-it can take a lot heat-far more than any dino oil and just as much as any other synthetic-but it tends to insulate, thus failing to provide one of a motors primary means of cooling off. This places a greater heating load on the engines cooling system, and in a hot climate and/or racing, every bit of cooling capacity helps. I took note when one guy had been studying synthetics to use in air cooled engines and found most of them rejected heat just like Mobile 1, and since an air cooled engine is cooled primarily by the oil, it caused those engines to overheat quickly! He waited serveral years for Valvoline to come out with a synthetic, and when they did he tried it and it worked. Subsequent studies revealed that Valvoline had apparently done their homework before coming out with the product and engineered it correctly to absorb heat.
But this was the late 80's. I haven't kept up with the progess, They all may be correctly engineered now, but I stick with what I know works.
I've lived in deep south Texas for years, and can say that I noticed a difference in engine cooling in the summer when I switched from Mobile 1 to Valvoline.
There's a lot of good stuff on the net now-a-daze I'm sure, so you may want to do some of your own research.
Just my $0.02!
Just my $0.02!
#35
I use the AMSOIL 0-W30. They say it will last about 20,000+ mi., but i usually change the filter every 4-5k and the oil every 8-10k. Works pretty well for me.
#38
dinosaur remains
I use Castrol 10w-40 in my truck. I also use Toyota filters.
I change the oil every 4000-5000 miles. I would consider synthetic if I had a brand new Toyota, but I don't, so I won't.:pig:
#40
Chevron Delo 400 15w-40 w/ factory filter. Changed every 5k. Its a dino oil used in diesels. I use Royal Purple in the drive train. Best combination I've found since getting my Runner at 187k in 2000. Now has 277k and runs like brand new!
Synthetics are great. Just be sure to be consistent. and to really be sure do an oil analysis. Some oils can go 10k before needing a change.
