MAF Cleaning Highs & Woes
Well I took the time today to remove the MAF in an attempt to clean it. I'd read a 1999 4Runner write-up but apparently the 1997 MAF is not the same. It appears that there are 2 wires set deep inside and not one, which cannot be removed like the 1999 version.
Upon closer inspection, I can probably stick a long Q-Tip in to clean it or spray some STP throttle body cleaner in there.
I wish I could have done a write-up here, but I didn't expect what I saw. Here are the pics:
Airbox removed, exposing the MAF:
MAF on it's own:
A closer look in the front of the MAF:
A look at the back of the MAF unit:
Has anyone with a 1997 4Runner done this before? Perhaps I just need a poke in the right direction...? The highlight of the day was the fact that I cleaned my throttle body.
Al
MAF on it's own:
Al
Hey Al,
I'm in the same boat with my '98. Its an early 98, I think the later 98's may have the other style MAF. I didn't do anything with it when I cleaned the throttle body.
Here's how I cleaned my '97 MAF sensor
I removed it from the airbox bracket and unplugged it. Then I sprayed contact cleaner (non-residue type bought at Home Depot) directly down the "X" cavity and over the metal contacts that connect to the plug. I used 1/3 of a can and really soaked it. Then let it completely dry before re-assembly. That was it. I had 77K miles on mine before the cleaning.
Hey Wayne,
That's what I was thinking too. Did you notice any improvement (in power or fuel economy) or was it more of just a routine cleaning thing?
Al
Al
Performance change?
I'm not sure if the MAF cleaning made a difference yet. I cleaned it one week after I did the silencer mod, then it started getting really cold here in SE Wisconsin. I was hoping to get a small improvement in MPG but I have not confirmed it yet. The truck is running great right now!
Originally posted by CLin9383
is it possible to get the housing off? maybe jay could shine a lil light on this subject...??thanks
Just use a dab of soap and water on the q-tip and clean the electrical part that hangs in the wind. I wish I could say I have done it myself. I have this same style MAF, but I dont have any problems and I use the stock air filter.
Jay
Jay
