'94 Tacoma Running Hot
'96 Tacoma Running Hot
Hi all. I've been a lurker for about an month and now it's time for my first post so here goes:
I own a '96 Taco 2.7L and it seems to be running hot sometimes. I'll watch the temp gauge climb a bit and then return to normal running temp rather quickly. This will happen whether I am driving or sitting idly at at stoplight. I was thinking it was a sticking thermostat but I wanted to get some advice before replacing. Any help is appreciated.
Thx.
Thx.
Heya Seth...Yep, sounds about right. That is what my 91 was doing before I replaced my thermo. Eventually it locked up tight and blew the seams on my old rusty radiator.
That happened about 5 months ago. It was about time to replace the radiator anyway.
When was the last time you replaced your coolant?
Is your coolant full?
Most likely a thermostat, but it wouldn't hurt to have your system pressure tested and then flushed.
I had my coolant flushed about 1 1/2 ago up north. I'll change the thermostat out and see what happens. BTW my original post stated a '94 Taco which is wrong. It's a '96 which I think is a first gen?
Thanks for the replies!
might be an air bubble in the system too............try letting the coolant warm up with the radiator cap off for a few to try and purge any air that might be trapped
Avenged
07-09-2015 07:55 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
