93 runner 1 ton'd
Rear shock are done! using the factory upper shock locations I build a new crossmember that I could bolt the shocks to. I used 1.5" tubing bent 2 peices at about a 65 degree angle and sleeved the 2 peices together with some 1.75" tubing. After finding where I wanted everything I welded a 3/4 x 10 nut into the ends so I could bolt everything up. worked out pretty slick I must say!
Notice the lower Rt of the pick to see where the bolt threads in and where the old upper shock mount is.
Been a while but here ya go!
Made a rear D-shaft with some left over parts.
Got the brakes done.
Detroit is in the front, along with a Tom Wood shaft.
#26
The height issue was an unexpected problem that I dident realize untill I had it rolled out of the garage. Seamed normal too me cause I had full size chevy's for so long. I have an LT1/ 700r4 that I will trans plant into it later, hopefully the V8 weight will bring it down a bit. Im not to keen on the 2" body lift the previouse owner installed either. If possiable Ill be taking it off or atleast lowering it by an inch.
#30
Born and raised in Oregon, Im military and just can't give up my residency to my home state. Needless to say I get great opertunitys to go wheelen in other states!
#31
I'll probably be steeling some of your tank idea's later on down the road. Like I mentioned before I need to ditch the body lift on mine but the fuel tank is going to need some rework. I will have to lower the tank so I can bring the body back down and the stock 4runner tank is a bit tall to be lowering it any more than I have it now.
#32
I have to say, I hate the gas tank location/size. Only thing I did to is was cut an access hole under the back/pass seat so I can reach my fuel pump.. I do NOT want to to have to drop that stupid thing again..
#35
Sreering
All the parts for moving the steering box foward, saginaw style pump, hydro assist and high steer.
I already had the Rt side arm.
#37
Removed the ABS bracket from the bottom of the ABS pump to reuse, the stock steering pump hoses clap to this bracket. So to make it easy I just put it back.
Made some brackets for the Saginaw steering pump from 3/16 plate.
Moded the original ajustment bracket a bit.
#38
Mounted pump, still uses stock size belt and had the stock hydro lines for pump moded to fit.
The stock steering pump has 2 vacum lines running into it, simply remove one and loop the other on into the empty port.
#39
Moved the steering box foward.
Had to clearance the frame on the bottom side so the tie rod nut on the pitman arm would clear.
Added a plat across the top with some flared holes.
Poerted the steering box for hydro assist and clearanced the core support and fender-well a bit.
#40
Using a stock toyota V6 power steering resivor I moded it for the cost of a $5 heater hose fitting to fit my application.
Drill out to 9/16, makes a nice fit later.
Made a quick mounting bracket and booger welded the fitting on the bottom, looks like crap but it dosent leak.
