93 PU sas, question on donor axle type
Old 03-09-2016, 03:07 PM
Squigglez's Avatar
Hey guys,
I have options to purchase the solid front axle from the following:
BJ70
BJ60
FJ40
Current rear axle is 58" in width, and I'd like to match that.
Hoping to keep my current T-case.
Old 03-09-2016, 03:13 PM
Squigglez's Avatar
I should say that by 'work', I mean with 52" toyota rear leafs and proper pumpkin placement.
Old 03-10-2016, 03:49 PM
ZUK
ZUK's Avatar
All 3 are passenger side diffs so they are just the same as your transfercase output.....all 3 are 9.5" low pinions.....the FJ40 might be an old 40 so maybe it has a coarse spline pinion so that's one tick against it. I'd say get the BJ70 front.
All leafpacks can be made to fit....just a slightly different placement of the frame mounts.
edit---also, the 40 is too narrow. The 60 or 70 is right at 58.5" I believe so if more width is needed there are always aluminum wheel spacers. My build uses a flipped FJ60 and 2" spacers on each side.....worked out nicely for me.
millennium falcon
03-19-2017 05:42 AM
3rnr
03-09-2016 11:06 AM
Ridge
03-09-2016 08:47 AM
TheEastBeaster
03-07-2016 06:11 AM
Quick Reply: 93 PU sas, question on donor axle type
