85 excab efi 4wd what's it worth?
Brand new rebuilt engine bored .30 over
Brand new ENGBLDR Street head w/ Oversized Stainless valves and 270 H.O. Cam
LC Engineering Ceramic coated header
LC Engineering adjustable cam gear injectors rebuilt by witchhunter
Brand new 5.71 gears with Aussie lockers Front & Rear
High Steer Steering kit
Rear disc brake conversion
IFS Hub swap & IFS rear axle 1.5" extra width
Battery/Intake swap
35x10.50 Super Swamper Boggers
14" Bilstein Shocks
Low Range Offroad Rear shock bar
Trail Gear 14" front shock hoops
Homemade front bumper w/ Warn xd9000i
Bucket seats from a 95 4runner (better side bolsters and adjustable lumbar)
I added power windows, not factory but used factory switches
A set of half doors will also go with the truck.
I have the tailgate and the tire gate. Both will go with the truck.
The
The bad that I can think of:
-The steering box leaks, I have the rebuild kit to go with the truck though.
-The blend switch broke behind the dash. I just manually worked it under the hood.
-The winch needs a solenoid to work
-The truck does have some rust in the body line of the bed, on the drivers door, and on the front drivers fender where I hit a deer but straightened the fender back out.
What do you guys think it's worth?
OK so I'm not completely out of the realm of reality. I've got it listed here in central Mississippi for 6k and would really like to get that for it, but i'm not set in stone.
junder28
25
06-21-2016 06:24 PM
hjalti_gto
08-24-2015 11:46 AM
