Ozarks Ozarks Chapter
Links to FAQ's and Info!
Old 10-10-2006, 08:13 PM
colsoncj's Avatar
Updated 4/15/09
Well I got tired of looking through several threads to find the thread I wanted, so I started a list of links to FAQ's and info about various things... Since its all nicely compiled I figured I'd share it. Hope this helps some of ya!
I'll keep adding to it, if I find more, and if theres some things that some of you know about, post them and I'll add them in!
General 4Runner/Pickup FAQ's:
.......... http://www.pirate4x4.com/forum/showthread.php?t=459180
.......... https://www.yotatech.com/~corey/tech/techpage.htm
.......... https://www.yotatech.com/~corey/4runner_faq.htm
.......... https://www.yotatech.com/forums/f120/toyota-faq-66255/
General FZJ80 FAQ's:
.......... http://www.sleeoffroad.com/technical/technical.htm
Online FSMs
.......... http://www.ncttora.com/fsm/
.......... http://www.4x4wire.com/forums/showfl...&Number=752426
AXLES:
Comparisons: http://www.pirate4x4.com/tech/bible/index.html
.......... http://home.4x4wire.com/erik/diffs
TOYOTA 8": http://www.4crawler.com/4x4/CheapTri...ch/index.shtml
.......... Rebuilding Info: http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4x4wire.com/toyota/mainte..._end/teardown/
.......... .......... http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
.......... .......... http://www.4x4wire.com/toyota/tech/gear_setup/
.......... .......... http://www.pirate4x4.com/forum/showthread.php?t=281879
Toyota Component Strengths (D44/D60 too): http://www.pirate4x4.com/forum/showthread.php?t=350905
D44's: http://www.4x4wire.com/forums/showfl...b=5&o=&fpart=1.
D60's: http://www.pirate4x4.com/tech/billav...ont/index.html
D70's: http://www.pirate4x4.com/tech/billavista/D70/D70.htm
14 bolt: http://www.pirate4x4.com/tech/billav...ble/index.html
Hybrids: http://www.pirate4x4.com/tech/billav...HybridAxle.htm
Rockwells: http://www.pirate4x4.com/forum/showthread.php?t=313836
.......... http://www.jpmagazine.com/techarticl...ton/index.html
.......... http://www.fourwheeler.com/techarticles/77419/
Lockers:
.......... Toyota 8" Air: http://www.4x4wire.com/toyota/tech/arb_locker/
.......... Toyota IFS Air: http://www.4x4wire.com/toyota/4Runne...ifs_airlocker/
Stock Toyota Engine Improvements and Info:
20R/22R: http://ttora.com/forum/showthread.php?t=84715
22R to 22RE Conversion: http://pirate4x4.com/forum/showthread.php?t=316661
22RE: http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
22RE Superchargers: http://www.toyotacatalog.net/M1WebGe...F-E6DF0C03E232
Engine Swaps into Pickup/4Runners:
General: http://www.mindspring.com/~jayk3/toyota/swaps.htm
.......... http://www.pirate4x4.com/forum/showt...hreadid=175795
Buick 231: http://www.off-road.com/toyota/buick_v6_swap.html
Chevy 4.3: http://www.off-road.com/toyota/tech/other/v6swap.html
Chevy 350:
Ford 302/351: https://www.yotatech.com/forums/f88/ford-302-351-swap-info-72065/
.......... http://www.whiteknucklemotorsports.n...d=38&Itemid=27
Toyota 3.4 V6: https://www.yotatech.com/forums/f160/3-4-swap-started-82145/
.......... https://www.yotatech.com/forums/f116/3-0-3-4-engine-swap-questions-81553/
.......... http://board.marlincrawler.com/index...&topic=19684.0
.......... http://www.andrewzook.com/content/view/22/37/
Toyota 22R to 22RE: https://www.yotatech.com/forums/f115...e-swap-129693/
Toyota 5M/7M: http://www.4x4wire.com/toyota/tech/supra/
.......... http://4x4.4t.com/4runner/7mswap.htm
.......... http://www.off-road.com/toyota/tech/supraswap/
.......... http://www.supracharged.com/forum/viewtopic.php?t=298
Toyota V8: https://www.yotatech.com/forums/f161/1uzfe-swap-into-2nd-gen-4runner-54771/
Toyota Diesel (1KZ-TE): https://www.yotatech.com/forums/f116/diesel-conversion-underway-77103/
Engine Swaps into FZJ80s
Transfer Cases:
Double Toy Cases: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.marlincrawler.com/docs/dualcase/install.html
Doubler Adapter for Toy Autos: http://www.gearslug.com/index.php
Double NP Cases: http://medusa.ih8mud.com/NP205/Doubler.html
.......... http://www.offroaddesign.com/catalog/doubler.htm
Toy Cases Info: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.off-roadweb.com/tech/0607...des/index.html
NP Cases Info: http://www.off-road.com/chevy/tech/transfercaseguide/
4Runner/Pickup Suspensions and Lifts:
SASing: https://www.yotatech.com/forums/f88/solid-axle-swap-has-begun-73430/
.......... https://www.yotatech.com/forums/f88/dirt-cheap-sas-well-close-73882/
.......... http://www.tacomaterritory.com/forum...isplay.php?f=7
.......... http://www.toyotaoffroad.com/Article...kleman_SAS.htm
Toyota Rear Springs up Front: http://www.pirate4x4.com/forum/showthread.php?t=265669
Chevy 63" Rear Swap: https://www.yotatech.com/forums/f31/chevy-63s-87-runner-71759/
.......... http://www.pirate4x4.com/tech/chevyswap/index.html
.......... http://www.pirate4x4.com/forum/showt...threadid=20665
4Links: http://4wheeloffroad.com/techarticle...131_0306_link/
.......... http://www.4wheeloffroad.com/techart...ension_part_2/
Coil Conversions: https://www.yotatech.com/forums/f88/finishing-coiled-over-idea-105460/
.......... http://www.offroadsolutions.com/susp...#7995_coilover
Body Lift + Flat belly: http://www.4x4wire.com/toyota/tech/drivetrain_lift/
.......... http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
FZJ80 Suspensions and Lifts:
Body Lifts:http://forum.ih8mud.com/80-series-te...body-lift.html
.......... http://forum.ih8mud.com/80-series-te...body-lift.html
4Runner/Pickup Steering:
.......... Rebuiding Stock: http://web.archive.org/web/200503220.../taco/box.html
FZJ80 Steering:
Winches/Winching: http://www.pirate4x4.com/tech/billav...ery/index.html
4Runner/Pickup Rear Bumper Design
.......... Mulit-mount: https://www.yotatech.com/forums/f88/front-tube-bumper-multi-mount-winch-87892/
Vendors: (NOTE: I have no connection to any of these, they are provided merely for reference)
ARMOR - Front Bumpers:
..... 4Runner/Pickup:
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
ARMOR - Sliders
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...iders_main.htm
..... .......... 4xInnovations: http://www.4xinnovations.com/pages/guarding/sliders.htm
..... .......... Hanna Quality: http://www.hannaquality.com/products.html
..... .......... Man-A-Fre: http://www.man-a-fre.com/feature_ite...ocksliders.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/sliders.shtml
ARMOR - Rear Bumpers:
..... FZJ80: 4x4Labs: http://www.4x4labs.com/bumpers.shtml
..... .......... Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/rearbumpers.shtml
AXLES/GEARS/DIFF PARTS:
..... FZJ80:
LIFT KITS - Body:
..... FZJ80:
LIFT KITS - Suspension:
..... FZJ80:
GENERAL MODEL SPECIFIC GOODIES:
..... FZJ80:
OTHER PARTS:
Aux Switches: http://4x4mods.com/Product/Jeep/Rock...rswitch40.html
Old 10-17-2006, 05:27 PM
colsoncj's Avatar
Online FSMs
Old 09-11-2007, 10:50 AM
Gator's Avatar
Thanks
I just posted a thread regarding a swap from the 3vze to a Chev 4.3 and happened to see this link at the bottom of the page.
Looks like you have some useful links here, thanks.
Old 09-11-2007, 02:30 PM
colsoncj's Avatar
no problem... i tend to update it every now and again when i find new stuff... if anyone finds any bad links, let me know, or if they find any links to add, or information to add, please PM me and i'll get it added right away!
Old 07-13-2008, 06:17 PM
colsoncj's Avatar
updated and fixed.
Old 03-12-2009, 10:11 PM
colsoncj's Avatar
updated again
runnermedic
13
09-21-2015 05:20 PM
HiLuxer
09-09-2015 02:43 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Links to FAQ's and Info!
