Greetings - new 2007 FJ owner!
Hi all... Just bought a 2007 yellow FJ. Someone on another forum linked me over here, and as soon as I saw that someone had done a LED dash swap I knew this was the place for me.
I also own MINI Coopers, and I've already done my first "mod" to the FJ, a set of hood stripes to match my Minis:
I wonder where a good source of info on the FJ's 4WD can be found? Specifically, I want to know the best way to use the Full Time 4WD system - I expect that most of the time, I'll be using it in "H" with only occasional use of the "HL" mode, and I want to be sure that the tranny is all set and ready to go when I *do* need to switch to "LL" mode. Should I run the car in LL mode every month just to make sure everything stays lubed and prepped?
Also, I'm looking for a good set of bull bars w/ skid plate in black. I have my eye on THIS UNIT, available over on AutoTruckToys.com:
I wonder with a unit like this if I won't be able to use the upper brush guards as well, though? Will I have to purchase a set specifically designed to work with a matching brush guard, or does the brush guard mount to different threads?
Thanks in advance!
Thanks in advance!
Welcome to the family!
The LL mode is just a different gear set within the transfer case the second L refers to the "locking" of the centre diff. which is also locked in HL mode. Because the FJ is going to be in 4wd most (all?) of the time I would'nt worry about having to keep everything lubed or anything like that other then perhaps a periodic check in an empty parking lot or such like just to confirm that all is working properly for when you DO need it.
Check through the FJ sub-forum here for lots of FJ specific info.
BTW I like those stripes now all you have to do is paint a flag on the roof.lol
happy New Year Aviator
Welcome, if you are looking for protection with that bullbar, if will not offer it. Those bars are for looks only. If you want front end protection then you need an ARB or TJM bullbar. Also do not run the vehicle in L mode on dry pavement.
EDIT: I looked up both the ARB and TJM parts, and they're both full bumper replacements, which is not only out of my price range and looks like more extreme-duty equipment than I need, but also are fugly as hell (IMHO). Looking at replacements from manufacturers like Romik, Westin and Aires, they look if anything more substantial than the Toyota OEM skid plate, since they all have additional thick, tubular steel surrounds - you're saying that NONE of these parts give ANY benefit whatsoever?
I don't forsee the need to install a winch on the front, which both the ARB and TJM units can accommodate... As I've never done any sort of serious 4WD driving (nothing beyond muddy, rutted trails, no rock climbing), do I really need to think about something as high-end as the ARB/TJM?
Welcome, nice FJ,
I'm not sure what you mean by brushguard, but if you are looking for hoops that protect the grill and headlights, then yes, the arb has them, I believe there is a tjm with them also (tjm has different model with no hoops, just a center hoop, and then one that covers the headlights too)
do a search on here for "Corey", he's got a FJ with plenty of goodies to make you drool
Oh, and before you start a new thread, the search is your friend (I'm not saying this about this thread, just for future reference)
kawazx636
10-06-2021 03:03 PM
buckz6319
08-05-2017 03:50 AM
smilen724
13
11-08-2015 04:11 PM
