rear axle housing problems
Hello. I have a 93 T-100 4x4 V6 5spd. I recently dicscovered that my axle housing is cracked and leaking gear lube. it cracked on at the welds on the passenger side spring perch. 3 sides around th welds are cracked. Anyone ever run into this problem? I work at a toyota dealer and have never seen or heard of this happening on any toyota trucks. Also, if anyone has a rear axle housing or complete rear end for sale I might be interested. I am going to try to weld the cracks but not sure how long it will hold. Any help would be great. Thanks. Froggy93
Seen a half dozen between the T-100 and the Taco.
The perches make things ugly.
Take a look at a new housing, but know if it is stock, it will happen again.
Well, welded the rear end up about a month ago. was looking around last week and found that it is leaking again from the same spot. I havent figured out if it is coming from the welds or was cracked farther Than I had welded. If anyone has one for 93 4x4 please let me know. I think I might have a friend tig weld it this time. Or, If anybody knows where I can get a beefier aftermarket let me know. open to any suggestions. Thanks.
mines crack too...i need a 90 yota v6 rear end..i dont no how it crack but i was stump to see it crack so im not driving it nomore until i get me a new one..anyone selling a 90 v6 rear end holla at me..
i have the same problem , i have broke the springperches on both driver and passenger and i am runnin it, i have welded them both and they are still cracked , when i have the time i plan to take the axle out and cut the perches off and start new, but till then i just keep checking the fluid and adding some
Check on craigslist...They come up all the time (at least around the PNW) just never when I have the extra cash , need one for my '81.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
