Sub Box Placement
Location: Yotatech, because Pirate is too expensive. NorCal.
Make sure your head unit knows there are subs there and that it is putting noise out the RCA. IDK what head unit you have but if you put the RCA on rear instead of sub then you should get noise even if the subs are turned off on the HU. Most HUs just have a set of rear pre-outs more expensive ones could have rear, front, and sub.
Thomas
You know what? Hes right. Thats why the terminals are on the same side of the sub. Usually they are on opposite sides. Wire it like the pic he posted. I'd bet cash it will work after that.
#25
Alpine Type R's come to mind as an example of a sub that has terminals side by side like that and ARE dual voice coil. However, like I said I am 100% sure the audiobahns are single voice coil. Let us know when you hook it up if that fixes it.
Oh, and by the way, the way you had it hooked up before was giving the amp an 8 ohm load and unless you had the gains and bass boost maxed out there would probably be very little sub movement at that high of resistance. The amp just doesnt make enough power at 8 ohm to move the subs much at all.
Thomas
#26
I have installed a few auiobahns in my day and all of them had that style terminals even though they were single voice coil.
Thomas
Thomas
#27
Anywho, back to the topic at hand.....ACSig, have you tried the different wiring yet?
Thomas
#28
No, just got home from school. My only problem is, am I supposed to leave one pair of terminals open (on the sub that is not hooked up to the amp)?
#29
its fine if theres an open set of terminals. look in your amp's manual and try to find what one beep means. also are there indicator lights on the amp that light up, specifically a safe/protect one?
#30
The brown lines are speaker wire. The sub not connected to the amp will have a set of + and - terminals open, the sub wired to the amp will have wire in all terminals taking advantage of the extra set. Hook it up just like the picture and you will have a 2 ohm load at the amp.
Thomas
#33
Here's a couple, I know they're not the best pictures, but my back window has a broken relay and I'm 6 foot, so I'd say not too bad for being crammed in the back of my 4runner.
#34
sounds like you guys got things all figured out, congratulations
should you ever run into anymore trouble or just want some good info on car audio check out this site its full of endless knowledge www.the12volt.com
#36
#38
Nice. If those are 2 12s then I'm screwed. The box I built for my 2 15s for the Camry is gonna be way to wide to fit in the runner. There is more space between the subs and the edges of the box than yours and the box is still to small for the 15s to breathe properly. Guess I'm gonna be building another box. I think I'll port it this time.
I'd be carefull with that if I was you, that chrome amp will be easy to see from far away.
#39
test amp
How about removing the inputs from the amp and hooking up a mp3 player to see it that works. use a stereo 1/8 to rca cord from the mp3 to the amp. make sure the mp3 player is turned down !!!! before you try.
#40
Looks good man. Glad everything worked out. Thats a lot of crome.......
Thomas
