1982: New Lighting
Well, now it looks like I actually have two headlights.
The fogs come in handy for those extra-dark country roads I drive on. Tried 'em out in some mild snow just a few minutes ago.
nice. for even better headlights, rewire them using a dual 30A relay setup, and some decent wire, and get some hella e-code housings, along with some good osram bulbs. (sylvania bulbs aren't really as good as you think)
get these, it'll be one of THE best headlight upgrades you ever do! http://www.rallylights.com/hella/200mm.asp
the housings you want are: HL72207
and you'll be amazed what rewiring your stock headlight circuit will do for bulb intensity!
+1 on the Hella e-code lamps. I run them on all 6054 applications and they are the bomb.
Relays help put more voltage to the bulbs. Bumping the voltage from 12 to 14v puts out more than 35% more light, so it's like running 75w bulbs instead of 55w bulbs... for free!
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
1982, 700ff, 75w, conversion, fog, grand, headlights, hella, hid, hl72207, lamps, osram, toyota, wagoneer, wreckedrex
