Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
installing viper 4704v
Old 03-10-2012, 04:40 PM
ggeiger3's Avatar
i am installing a viper 4704v remote start and keyless entry on my 97 4 runner, i have the door lock and unlock working but i cant figure out the starter. it is a manual
this is for the remote start 8-pin harness
1 + ignition 1- blk/yel
2 +12v dc constant input for ignintion 2 and flex relays- wht or wht/rd
3 accessory ?
4 starter output- blk
5 +12v- ?
6 + ingition 2/ flex relay output
7 + flex relay input 87a key side (if required) of flex relay- ?
8 + 12v dc constant input for acc and starter relays -?
from what ive found online those are where i hook up the wires. the ?'s are where i cant find anything or am confused
any information would help thanks
ive already bypassed the clutch safety switch so i dont have to do the shutdown procedure
Old 03-13-2012, 02:08 PM
drpdmazda's Avatar
what are the questions you have? you should have a purple and a green out of the main harness from the alarm. those are for your starter kill. you cut hte starter wire and solder the purple to one side, and the green to the other. I think its purple to the car and green to the key side, but im not 100% so read the manual and do as it says.
accesory is the orange wire coming off the brain.
12 volts is needed to power the system.
Old 03-13-2012, 02:16 PM
ggeiger3's Avatar
idk im just gonna pay somebody to do it this is ending up being more hassle than its worth.
Old 03-14-2012, 12:16 PM
drpdmazda's Avatar
what hassle are you having? it may seem like a lot but it is really a pretty straight forward and easier install.
Old 03-14-2012, 09:22 PM
ggeiger3's Avatar
well like on just the remote start harness there is 3 wires that say 12v constant, does that mean all 3 of those wires are all hooked up to a 12volt constant,
Old 03-15-2012, 04:49 AM
drpdmazda's Avatar
if you are talking about the 3 red wires, that are fused off of the brain, you can tie all 3 of them together and just run one 12 volt wire. splice 2 of the red wires into the 3rd close after the fuses, and just run one wire to the ignition harness. that way all 3 of them get 12volts.
hope that makes sense
j
nvdesertrunner
05-11-2020 08:18 PM
wwjr
09-07-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: installing viper 4704v
