Which torque spec should I use
Old 04-12-2017, 03:03 PM
TheMaxfield's Avatar
I have an 82 pick up 2wd (22-R) I just changed the head gasket on. the truck ran befor I chandged the head gasket. now I don't have enough compression (90-100 psi dry compression test) and the truck won't start or run just cranks and back fires. When I did the head gasket I replaced the head bolts with 1995 22-RE head bolts becaus they were all my parts store had or could get. so I put the truck back together with new head, exhaust, and intake gaskets, then put in my new 1995 head bolts and torqued them in three stages to 44 ft pounds then 1 quarter turn than another 1 quarter turn. Should I have used the 1995 tourque instead? It's 84 ft pounds.
thanks guys!
Last edited by TheMaxfield; 04-12-2017 at 03:16 PM. Reason: Forgot some important info
Old 04-12-2017, 07:42 PM
millball's Avatar
Best I know all 22r type engines go 65fp
Old 04-13-2017, 09:50 PM
I increased my torque to 65 fp and well i was in tightening my head bolts I noticed my valve timing was off 180 degrees. I got that all figured and now this truck starts and runs great!! thanks for the help guys!!!
