No Shock Bushing? Ok to keep it that way?
Driving to class today I heard and felt a rattle type noise right under me feet going over speed bumps or any other kind of bump. So when I got back home I looked under my truck and noticed that the drivers side shock bushing was not there. I check the passenger side and it was still intact and looks to be in good shape. My question is, that if i keep it this way will anything happen? Should I tighten it back up without a bushing? Would that be ok to ride with?
Drivers Side:
Passenger Side:
Drivers Side:
Passenger Side:
Will it hurt anything in the short term to run without it? Probably not, but at least tighten it up. You will probably still hear creaking/squeaking without the bushing though, and eventually, you might start to wear down the metal on your upper shock mount where the shock will be rubbing on it. I would plan to get one and install it in the near future if I was you.
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
