Hope its not my head gasket!!!!
for the past couple of months my coolant has been looking a little milky.....about six months ago i did a system flush and i now see that it is milky again. i know this is a symptom of a leaky head gasket....but is there any other possibilities????? i would rather swap in a 22re than just rebuild the 20r. any help would be much appreciated!!!!!
the guy that i bought it from said he had a problem with the farthest back spark plug fouling out....i bought the truck a year ago and changed the plugs and switched to a webber and have never had that problem! a nd come to think of it that fouled plug was white.
Whats the condition of the timing chain?
Its possible for the timing chain to become loose and wear a hole in the timing cover and cause oil and coolant to mix.
First thing you should do is a compression test.
if his timing chain is loose then it will have that ticking / rattling sound right?
my best guess is just a leaky gasket....somthin real small! because there is more oil psi than psi from the cooling system (especially cause my truck never gets up to opp temp) it is very possible that there is just a little oil in the coolant! but thats just a guess!
My Runner has a small head gasket leak. I lose a little coolant over a period of time, no water in the oil or oil in the water. Aside from the coolant loss, the most noticeable symptom is excessive steam coming out the exhaust pipe, especially when the engine is cold.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
