View Poll Results: Change to syn. oil in high milage trucks
OK
159
74.30%
not OK
55
25.70%
Voters: 214. You may not vote on this poll
Last edit by: IB Advertising
Browse all: Toyota Tundra Engine Guides
- Toyota Tacoma How to Change Engine Oil<br>Step by step instructions for do-it-yourself repairs.
- Toyota Tundra How to Change Engine Oil<br>Step by step instructions for do-it-yourself repairs.
Change to synthetic oil on high miles truck
well, depends...i remember posing this question when i got on here and the answer i got was something along the lines of the particles in synth is smaller and if you have been using dino oil, and you switch over..the synth particles may be smaller and you may have leakes...or SOMETHING to that extent...but anyways..i was hesistant and decided not to...i'm sure someon else can better explain the jumble i just explained....sorry if i confused anyone...
I run synthetic in my truck and I'm rapidly approaching 150k. And don't let the miles fool you - I just did my emissions test yesterday - I was so far below the permissable amts you'd think the truck was new or at least the engine was. If you are very concerned about the oil being too thin then try 5w40 Mobil Delvac or Shell Rotella. If you have leaks then yes the leaks will probably be worse but I personally have never seen a non-leaking engine start leaking because of synthetic.
I have never heard of that happening.
I have been running Amsoil 10-30 now for a few years on my engine.
The chassis has over 170K on it, and my engine has around 55K or more on it.
I just had the Amsoil taken out today, and new put back in, and I have been running this last batch since August.
I checked it yesterday, and it was right on full, not a drop burned, or leaked, and the oil looked almost like it was new.
Not dark like dino oil would be.
I have worked at a Grease Monkey for over a year and had a good talk to a Mobil 1 rep. They say that it is ok for you to put in Synthetic in your engine.
I hope this help, this is what Mobil Had to say about it:
Myth: Mobil 1 will leak out of the seals of older cars.
Reality: Mobil 1 does not cause leaks. In fact, new Mobil 1 with SuperSyn™ was tested in dozens of industry standard and OEM tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made.
ExxonMobil engineers are wary of conventional oils that tout their use of additional seal-swelling agents. With extended use, these agents can over-soften engine seals, resulting in leaks. More to the point, an oil additive will not rejuvenate worn or damaged seals. The damaged seal may have been caused by a worn rotating metal component in the engine.
If an older engine is in good condition and does not have oil leaks, Mobil 1 with SuperSyn™ provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1 with SuperSyn™. ExxonMobil also always recommends following the automobile manufacturer's manual for the proper oil to use.
http://www.mobil1.com/why/myths.jsp
Sounds like a good info trdtoyota just put out. I used Amsoil 10W30 synthetic oil in my engine since new and I never had any problem with synthetic. The engine now has 89k miles and I changed my oil every 7500 miles. I have an Amsoil 10W30 since August and I have not had the chance to change the oil yet but every time I pulled the dipstick for inspection the oil always appear new, no burnt smell or anything and I can still feel that viscosity.
So I guess if your high mileage engine is in good working condition, using synthetic won't make it leaks.
Noel
Noel
I don't know if this is correct or not, but I read somewhere not long ago that you shouldn't put synthetic in a high mileage engine that has been on dino oil its whole life. The reason was that the detergents in the synthetic oil would break loose deposits left by the dino oil. Like I said, I don't know if it's true or not, but it's something else to think about. I actually started putting synthetic in an 83 Toyota pickup with 106k miles the day I bought it. If I had it to do over, I don't know if I would have done it, but it's been over a year, and (knock on wood) no problems yet. It did worry me when I read that though. If I can find that article, I will post the link here.
The question I have is: Is it OK to put synthetic oil in a NEW engine? The toyota dealer told me not to use synthetic until at least 5,000 miles because they said the engine would not break in properly.
Anyone know if thats true?
I changed mine to amsoil at 150k after running dino the whole time and I'm at 170k now. Before I switched I burned very little oil. Now it seams I have to put a quart inbetween each change, but my change intervals are now 10k rather than 5k. Other than that I have found nothing wrong. I haven't found much of an improvement either though. I did run the amsoil engine flush too.
Steve
Steve
I can't find the exact article I read, but here is a similar one:
http://www.pecuniary.com/faq/high-mileage.html
Good to hear all the positive AMSOIL stories. I have a case of their gear oil on the way to put in my diffs, tranny, and transfer case. I'm hoping to switch to their motor oil eventually too.
AMSOIL actually has a very strict "switch-over" process that involves using their motor flush, with a fresh filter, to loosen and remove all the old deposits in the engine.
I'm going to start using Mobil1 Synthetic with a few frequent changes to do the same thing. After a few 1500 mile changes with the Mobil1, the engine should be pretty clean and ready for the AMSOIL.
I'll probably even drop the oil pan and clean that out as well. Alot of gunk can collect there.
__________________________________________________ __
That's basically a marketing ploy and more profit to Amsoil and not actually needed. I don't know the make-up of Amsoil's flush but one of the very best flushing fluids for your engine is made by Lubriplate and is called CFL Oil, part number L0859-054.
That's always a good idea.
I've used the high Mileage old before. I really didn't notice a differance in the oil thought. If you go with a high mileage oil I would refer you to Valvoline Maxlife. I belive that Valvoline has the cleanest oil (non- synthetic oil) out on the market. if you pour it out in to cups and compare it to, say, Penzoil or Quaker State (both Penzoil and Quaker State are made by the same company), the Valvoline looks much cleaner. So my vote is for Valvoine.
One thing I forgot to put in the synthetic part was the synthetic blends. I have learnd that a majority of the blends only have about a 1/4 of synthetic oil in them. One Blend I know for sure that is like that is Quaker 4x4. I can't see my self justifying paying for that oil when I could get a full synthetic for a couple of bucks more.
Know that I have made my big stink I hope this help also!
Personally I would wait until the first oil change. Many cars come from the manufacturers with a special breakin oil. Even though many cars come with synthetic oils I wouldn't put it in a new engine that didn't come with it - the cam and valvetrain may not be ready until the break in oil has its lifespan in the crankcase.
As for detergents - ordinary oils have a lot more detergents. Synthetic is parafin based - synthetic will keep waste in suspension but doesn't actually have the detergents to scrub like ordinary oils do.
Originally posted by JSB
I just changed my oil yesterday and I thought I would try some of that High Mileage Oil. For vehicles with over 75k. Have you guys tried this?
This oil seems to get brown a lot faster than the old Havoline 10w40 I was using before, but it could just be me too. Time is proceeding far too quickly.
While we are the topic of oils, what doe the numbers in oil mean?
like 5w40 10w40 20w40 20w50 etc....
Steve
