timing sprocket
timing sprocket
i had a blown head gasket. so i removed everything to get to the gasket. somehow i moved the camshaft. the timming sproket gave trouble putting it on. i moved the sproket to fit on the camshaft.once i got allback together and wont start. anyone here can help me on this on. oh the float bowl doesent have gas sitting half way like i should. please help this is my only ride. thanks
You probably moved it out of time by one tooth, it should still start but probably run a little ruff, once you get it running recheck the fuel level in the float bowl and see were its at.
09-04-2015 09:27 AM
