Swaybar bushings
hey guys so since im on vacation i decided to take some advise and removed the sway bay although it didnt fix the clunk i found the little bastard. its the damn skid plate, im assuming the red neck who had it before didnt know ˟˟˟˟ about cars cause the skid is on with electrical wire. so tomorrow ill put it on right drill some new hole and tap them or figure another way to mount it. once my new energy suspention bushings come and i get new endlinks cause i snaped one taking the sway bar off im gonna put it back together right. i just cant see to get used to that much body roll. i did have another question cause when under breaking hard it pulls to the driver side. my first mechanically inclined thought was a stuck piston in caliper but just looking for others thoughts
ok so today i decided to take the skid off and low and behold the rattle is still there, not sure what else it could be. Any ideas. im going to do a complete brake here in a few weeks so ill find what ever is cause it to haul check tire pressure it was down, aired it up and still does it. so i will find out what it is. But anyone have any ideas whats causeing the rattle, only hear it on fast bumps or large bumps if im going slow just crawling i can go over everything and dont hear it but when i speed up i hear it more. any idea people please and thank you?
#25
good idea junkers but i also came accross this https://www.yotatech.com/forums/f128...4runner-76360/
#26
#27
Hey guys i uploaded a video today from my phone to youtube of the rattle so take a look and let me know
http://www.youtube.com/user/MrPumba1239?feature=mhsn
#28
Hey guys instead of starting another thread just decided to come on my thread. I noticed the other day that breaks had a shutter like feeling to them. Well today i when to stop at a stop sign and nearly t boned a new chev truck. The pedal was hard and wouldn't go to the floor i noticed i have a slight leak in a rear line but would that cause my issue?
#30
If you are getting it inspected anyways, you might as well just let them tell you exactly what needs to be fixed, then you will know what is wrong and then go from there.
#31
Well i don't want to spend the money for someone to tell. I donto have that much money with a new born. So important trying to do it all on my own.
#32
check your steering components. My truck always had a bad clunk it it and it ended up being the idler arm.Replaced it and no more clunk and it made the thing drive better.
#33
That's understandable, but what I am saying is that you said you are getting it inspected, so why don't you just bring it to them, and then they will tell you what needs to be fixed. It won't cost you anything extra...
#34
just for them to put it on the lift and look too see costs what an inspection does no it doesn't cost much but thats is money to help buy what's needed if you know what i mean. My inspection want until august and wanna get everything fixed before then.
#35
Ok, just thought it would be an option because when i got my truck inspected, i paid 50 bucks for the inspection, they wanted way too much to do the work for it to pass (balljoints and idler arm, they wanted $1100), so i did it myself, took it back to them, and he took a quick look at it in the parking lot and signed the papers for me (he wasn't very happy ) but it worked out quite nicely.
Just my experience.
Just my experience.
#36
Ok yeah i know it needs body work for inspection. On my way home from work i decided to see if my brakes were still being weird. Well turns out that they are and since its 10pm and quite i can hear things i couldn't during the day. When doing about 50km ph to stop as if something jumped out in front of me its like the brakes were grabbing. Warped rotors maybe? But at slow speeds like 5 kmph and there is a slight grinding id say. So im thinking maybe breaks just need to be done. Black95toy how do you check idler arm and where is it?
#37
So i took ny truck to the garage. Too damn wet and cold to be doing in my back yard. Well both rotors are completely screwed. Pads are near worn out. Shoes are metal and drums are rotten. So that should fix that. Now for the rattle while on the hoist i noticed that a front shock mount is beat out so they are gonna fix that too
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
justdifferentials
09-05-2015 06:52 PM
