Oil filter change on 2000 3.4L
Old 06-17-2010, 08:44 AM
Wasatch Rebel's Avatar
I've had my 2000 for a year now, and the first time I got the oil changed, I took it to Jiffy Lube or another place like that. Now it's time to change it again, and I'd like to do it myself. I've found out that the easiest way is through the driver's side wheel well--at least that's what some people say. So, when I lift up the flap under there, what I see doesn't look like the oil filters I'm used to. There's a round cap with a nut in the middle. I'm assuming this is the filter housing. Well anyway, I don't know what the steps are for removing that cap and replacing the filter. If you could help me out, I'd appreciate it.
Old 06-17-2010, 09:18 AM
B. Graves's Avatar
there should just be a filter there. on my 98 tacoma and my dads 97 4Runner (both 3.4s) you can see the filter from the driver wheel well. you got a pic of what youre talking bout?
Old 06-17-2010, 09:23 AM
Atomic's Avatar
http://www.4runners.org/writeups/oil/index.html
The oil filter is labeled "B"
Other maintenance can be found here: http://www.4runners.org/
Old 06-17-2010, 09:25 AM
scuba's Avatar
http://www.ncttora.com/FSM/2003/Repa...e/oaf/repl.pdf
Old 06-18-2010, 03:29 AM
I now know that this ain't the filter, but what the heck is it? Is the filter lower than this photo is showing? Sorry about the quality. I was thinking originally that the round thing at the top of the picture must be the filter housing or something, but I don't think that anymore. I think I need to crank the wheel to the left and try looking again.
Old 06-18-2010, 05:38 AM
theMonch's Avatar
Oil Cooler
That is the 5VZFE oil cooler. The engine coolant is bypassed out of the water pump and into the cooler assembly. Thats what the hoses that are attached to it are.
The oil filter is to the left more towards the front of the motor.
Old 06-18-2010, 06:32 AM
Okay. I see. Thanks a bunch. I'll go out there and give it another look.
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Oil filter change on 2000 3.4L
