LC engineering engine swap... Help!
Hello all! I need help. I have a 93 toyota pickup 4WD. My roomate urged me to purchase an LC engineering 22re Stroker engine after my head gasket went out on the stock engine (271,000 miles!). Anyways I dropped a bunch of money on the new engine, cluch and headers. But my roomate who was sapposed to help me put it in has moved and now i am stuck. i haven't worked on vehicles to much but have a basic knowlage of things. If anyone has done an engine swap and has pictures and advice please post them. I want to put the engine in myself but i'm going to need some help along the way. Things i need help with... New cluch instalation... i've never put one in and don't know how to go about it. Also the instructions for the headers i purchased from LC say not to use any header wrap... Does anyone know why? And last if anyone has pictures of there 93 pickup engine so i can see where all the vaccum lines go that would be awesome!
thanks
thanks
yaeh take lots of pictures.. its pretty straight fordward to take out a 22re.. motor mounts undone there is 12 bolts around the engine and tranny.. 2 of them coming from engine back into tranny...
just pull engine and so the clutch and everything while its out.. yuo will have a amazing engine and truck when you are done and will have learn alot...
before summer i did my clutch on my 22re... never did more than brakes before and yotatech got me through it!!!
YOU CAN DO IT!
YOU CAN DO IT!
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
22re, engine, engineering, engines, gasket, head, instalation, lc, lcengineering, motor, stroker, swap, swapping, tech, yota
