i hate to ask but what is high pinion
It's a high pinion
Seriously, with helical gears, the pinion can't be right at the centerline of the ring gear. Low pinion puts it below the centerline, high pinion puts it above the centerline. Obviously, HP has better ground clearance and usually better driveline angles.
High pinion gearsets are approx 30% stronger in the FRONT axle than low pinion because the teeth engage on the drive side instead of the coast side. HP diffs are WEAKER in rear applications for the same reason.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
Jcrawl94
10
10-24-2015 04:34 PM
klavender1
08-15-2015 01:51 PM
trailgoat
08-13-2015 05:54 PM
kirkrunner
07-27-2015 07:59 PM
