help with codes
help with codes
I am new here. hello all. 88 4runner 22ri fuel injected. a week or so ago started having trouble with idle revving up and returning to normal(cyclical) this happened only when my foot was on the brake . I rotated the tps a little, tweaked the idle adjustment a little.. ran fine for a few weeks. then the other nite it would start up fine then die in a few seconds. adjusting the TPS and idle setting screw didnt help this time. being heavy with the throttle not only doesnt help, it seems to make it die faster. i am thinking maybe vacuum, but cant keep it running long enough to try the vacuum tests i have found on this great forum. did some research today and got the codes. as best as i can tell they are:
24 - intake air temp sensor(THA)signal
31 - air flow meter signal
51 - switch condition signal
the thing is i have no idea what this info means or what to do with it...
any suggestions? ideas?
thanks in advance
tim
thanks in advance
tim
When I bought my '88 early Dec, It was getting code 31 and it was starting, but only staying running for a few seconds. What I did was unplug the Air Flow Meter (AFM, MAF, VAFM, etc, its the gray/silver thing on top of the air filter box), blew on it, plugged it back in and it started up and I haven't had a problem since. Read through this site: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
I can't comment about the other codes, sorry.
also, its a 22re, not a 22ri
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
