front diff burning up
My front diff smokes and smells like oil sometimes when i use the 4wd. it stopped doing for about a month, then it just started doing it again. so now i changed out the oil in it and it worked for a day, but then today it started smoking again. the 4wd is actually working but its smoking and smells alot. does anyone have any ideas. thanks
Sure it's filled up enough? It's kinda a PITA to fill ... need to spin the gears a bit and then fill it some more...
What did the oil look like when you drained it out?
What type/weight oil did you fill with?
Sorry I can't help diagnose your problem, but if in the end you determine there is a major problem with your diff, I've got one available.
https://www.yotatech.com/forums/f11/...uff-az-161011/
thanks for all the input guys, but i found out that its not even my diff at all, its the cv axles burning up because all the grease came out of the boots. so im gonna replace the cv axles probably this week. i also found out my #2 piston is only running at 70 while the rest are at 150. good thing i was planning on buying a new performance engine within the next year, but i guess the week engine will do for now.
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
