front 3rd, 54 mm socket??
Old 04-20-2010, 09:05 AM
gary_the_4runner's Avatar
wanting to install gears in the front axle. found this helpful site to help me not forget a step
http://www.4x4wire.com/toyota/mainte..._end/teardown/
but i do not have a 54mm socket and was quoted a price of nearly 50 bucks for it (baxter's)!!
i know i can do the rear axle, but since i dont want to deal with buying a socket i will use once OR damaging my cone washers during removal, im wondering if it would be better to have a shop install the front...
what is a fair price for a shop to do this for me?
if i install the rear third (4.88), and temporarily drive it to a shop with 4.10's in front, do i have to disconnect the front driveshaft? or just not put it in 4wd?
Old 04-20-2010, 09:15 AM
waskillywabbit's Avatar
Buy a 54mm socket and do it yourself.
Old 04-20-2010, 11:00 AM
85TurboRunner's Avatar
I'm sure a shop will cost a heck of alot more then the socket, and they will only install it once.
I got my socket for like $15.00 from some online place years ago.
How do you plan on messing up your cone washers? They aren't a fragile part.
Old 04-20-2010, 11:51 AM
4runner Freak's Avatar
Marlin $25
http://www.marlincrawler.com/hardwar...ls/54mm-socket
Trail Gear $14
http://www.trail-gear.com/54mm-spindle-socket
Old 04-20-2010, 12:03 PM
94sasyota's Avatar
marlins is a little more heavy duty being that its a 1/2 drive and powder coated.The trailgears is a 3/8 and not powder coated but for the amount of TQ you but on it and the amount of time you use it. i would just go with the trailgear one.
Old 04-20-2010, 12:13 PM
runneroffroad's Avatar
ya i got 5.29s in the back of mine and 4.30s in the front. just dont put it in 4wd. i removed the front drive shaft so i wouldnt forget
Old 04-20-2010, 01:40 PM
Staceman1's Avatar
You can also borrow a buddy's 2 1/8" socket. Works just as well.
Old 04-20-2010, 02:54 PM
Skinsfan6's Avatar
I will probably be verbally abused for admitting it, but I have many many times used either a 2 1/8" socket or a large flathead screwdriver and hammer to get mine loose and tighten them again with success.
Old 04-20-2010, 03:03 PM
Can't use a torque wrench with a flat head screwdriver.
Old 04-20-2010, 07:09 PM
Skinsfan6's Avatar
Pffff. My forearms are torque wrenches. I am the definition of the shadetree mechanic.
Old 04-20-2010, 07:39 PM
BigBluePile's Avatar
Geeeezus....
Use some 2.5" exhaust tubing and make your own...
Old 04-20-2010, 07:56 PM
trail gear for the socket $14
harbor freight for the brass punch $8
while im in there, i might as well service my knuckles, right???
i dont have a press, what size socket do i use to set races???
what is the preferred packing grease?
Old 04-21-2010, 04:19 AM
You don't need a press.
Numerous write ups online how to service a SFA (4crawler) as well as the FSM at ncttora.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: front 3rd, 54 mm socket??
