crankshaft position sensor
Old 10-22-2010, 05:53 AM
eddlg01's Avatar
I have a 1990 3.0L 3VZE engine and i need to know were is the crankshaft position sensor located. i have no spark from the coil.
can someone give me advice
Old 10-22-2010, 06:22 AM
Lysmachia's Avatar
Try the factory Service manual for your year...
http://www.ncttora.com/fsm/1990-1995...5/contents.htm
Old 10-22-2010, 10:40 AM
eddlg01's Avatar
Thanks for the service manual, hope this work
Old 10-22-2010, 11:10 AM
just call me smithy's Avatar
correct me if im wrong, but i beleve the CPS is actually part of the distributor. its deffinitly not like 5vz witch has the reader on the crank-pully, so ya im almost sure its apart of the dizzy
Old 08-18-2014, 06:39 PM
Mr3vak's Avatar
That is correct! Replace this when you replace the plugs and wires as well!
Old 08-18-2014, 06:54 PM
Mr3vak's Avatar
Old 11-01-2014, 10:47 AM
Alex904r's Avatar
have an 89 3.0 with possible bad CPS. Following these comments above, is the CPS on the crank pully?
Thanks
crammit442
7
11-29-2017 12:30 PM
markwink
08-18-2015 12:38 PM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Steven.m.paulk
07-24-2015 01:44 PM
Quick Reply: crankshaft position sensor
