Sponsored by: CARiD
Best way to remove rubberized undercoating
Old Dec 26, 2011 | 09:57 PM
Yotamonstah's Avatar
so i stupidly sprayed my entire floor with it, and did a horrible job, and it flakes bad because i sprayed it onto a dirty truck floor. how should i go about getting the floor down to bare metal?
Old Dec 26, 2011 | 10:05 PM
MP's4R's Avatar
hit it with a grinder that has a wire wheel, maybe have a shop vac handy for the mess, itll help prep the surface for the next application aswell.
Old Dec 27, 2011 | 02:23 AM
wyoming9's Avatar
Wink
If it is on as poor as you say a wire wheel should take it off.
If your talking about really good undercoating depending where it is oxy-fuel torch burn it off hit with wire wheel.
A good air powered gasket scraper works good.I have used a air hammer with a real wide chisel blade.
I have used the spray gasket remover with a putty knife.
I have at times used all of the above on the same vehicle
I repair a lot of floors where the under coating can be quite stubborn to remove
Old Jan 3, 2012 | 12:27 PM
BIGTOY88's Avatar
Go with the wire wheel. I had to do this a few years ago when I repainted one. Its a pain to clean up that way but takes it off a lot quicker.
Old Jan 4, 2012 | 08:39 AM
4biker's Avatar
I'd try wire wheel first, but beware of a huge mess. Wear something you don't care about. I just learned that power steering fluid dissolves undercoat, or at least it did on my dad's '02 Acura TL. It just wipes right off!
icentropy
Sep 16, 2020 02:47 PM
nvdesertrunner
May 11, 2020 08:18 PM
Jamie4runner2000
Jun 20, 2016 09:13 AM
chuckross1957
Sep 7, 2015 09:34 AM
trailgoat
Aug 13, 2015 05:54 PM
