22RE vs. 3VZ-E
For these 3vze that are overheating without towing or carrying a heavy load, I would say the cooling system was not maintained properly, no fault of the engine itself. There is a problem for people who cannot do their own maintenance, that it is generally lacking if you have to pay major dough at the stealership. Taking care of your vehicle means preventative maintenance, which can get pricey if you cannot do it yourself.
be sure to use the PROPER fluids in the 3VZ (and 22RE of course).
previous owner used some kind of green coolant in the cooling system of my '92 4runner..and it's allll kinds of rusted up..i can only imagine what the cooling passages of the block looked like before i had it rebuilt.
i will have more to say on this topic when i get my 3VZ back into my Runner
For the record, my 3VZ had rod knock, because the oil pump gave out i believe. lol that's the only thing i've found wrong with it...but there was more problems because of the bad bearings.
oyah it's most likely the water pump that seems to go like clock work on 3vze's? rightnow my buddy's 4runner is sitting because it most likely needs a new water pump, power steering stopped working, has a oil leak that we couldn't. and basically he is just tired of the thing. i checked the history of my truck and its only had one new water pump done. if i owned a 3vze i would right away replace water pump, timing belt, rotor and cap and the whole 9 yards because i don't trust the thing lol. where as my 22re i dont worry about it ever. get in the mud with a 22re and it will become your friend very fast haha 5000rpm for 10 mins and it doesn't get hot = beast
i have around 200,000 miles on my 3vze and the only issue i have is a lil oil leak coming from my valve cover. every toyota v6 i know have around the same milage as mine and dont have issues at all. like mentioned the proper maintence and care means alot. oh and i mud my truck like a maniac and have yet to have it over heat. lol but who knows?
#26
170K on the clock on my 3VZ. Had the headgasket done under recall. I replaced the water pump, timing belt, and tensioners strictly as preventative. The radiator split so I replaced that. I also replaced the valve cover gaskets once a while back. Besides that I've done nothing to it. I have the ISR mod with a K&N drop in a Borla Catback. It's been strictly a wheeling truck for the past 3 years and I rod the crap out of it. Never had any issues with it and with 37's and 5.29's I can cruise down the freeway at 70mph with the cruise on and the AC running. Try that in a 4 banger. 91 Yota I see you have nothing but bad things to say and everyone of them starts with my friend or my buddy or my parents.. always someone other than yourself. I'd venture to guess that the majority of the issues they have had is because of neglect not the engine itself. Don't knock it till you've tried it.
#27
#28
My 22re is great, just dont expect to get anywhere fast.
Im running 31s with 4.10s, 235,000 miles, and it cruises just fine on the freeway. I usually sit at 65mph, and it will pull up slight hills in 5th,
bigger hills in 4th,
over the mountains drafting a semi truck in 3rd
The main reason i wouldnt get a 3.0 is that it is a pain in the ass to work on. 22re gives you much more room to manuver in the engine compartment.
Or get a 3.0 and swap in a 3.4!
#29
#30
haha idk i must be one of the few that loves their 3vze. i dog the crap out of mine and it takes with out a problem. i would gladly put another one in my truck or buy another truck with one in it. i would actually take a 3vze over a 22re but thats just cause i have had good luck with mine i guess. i mean come on 200,000 on a motor is pretty good imo and im sure there are people with more than that. my bro's 3.0 in his ford ranger has been rebuilt 2 times and and his only has 120,000 miles. have you heard of a 3vze that has have to been rebuilt twice with only 120,000 miles??? lol
#31
Oyah i wouldn't own a 3vze lol hence i bought a 22re Look im not saying all is bad with the v6 but come on the 22re is a much better power plant hands down? i have driven the 4runner a few times so its not like i dont know anything. just my honest opinion is that the 22re is better! you can say all you want about "SOME" 3vze's being decent but there are far more that are crap. and obviously if the 3.0L was well maintained than he might be fine, but he is buying a used truck, from some guy he doesn't know? idk about you but id rather have the 22re that can take abuse rather some abused 3vze? all i hear all day is how people hate there 3vze? am a wrong? am i the only one that see's on 90% of the users on this site that own 3vze's, put "3.slow", or "3.suck" in there sig? but everyone who has a 22re just puts "22re" and they have nothing but good things to say? i have had some ruff patches with my 22re, not going to lie, but even when it was running bad its still got me around and didnt give up. proud to own a 22re and glad i didnt get a 3.0L
To call the 3vze "crap" is a pretty broad statement. What do you mean by a "22re that can take abuse or an abused 3vze"? Do you mean the people who run their vehicles into the ground without maintaining them? If you don't maintain the 22re, such as the timing chain, and it breaks you are looking at some serious engine repair. Not so with the 3vze. If you set the reputation the 3vze got from the head gasket recall aside, it really is a pretty solid and unstoppable engine.
#32
i know you weren't only directing this at me but i have had two 3vze 4runners close to me and they where both crap. parents owned a 1990 3vze 5spd 4runner since new till a few years ago. guess why we dont have it anymore??? you guessed it because the engine started giving up at only 312 Km. about 100k before that it started overheating on my mom then it worped the heads and intake. crap. Now my buddy owns a 91 2door 4runner 3vze 5spd, at 350K km. still runs but overheats all the time. he stopped driving because of it. he would be just cruising down the road to work, truck under no major strain and it would get hot. he would always make sure the rad was full and do proper oil changes but it couldnt handle it.
now my 22re never gets hot and doesnt give up that easy. iv been on a 6 hour trip all up hill on the frazer canyon in the middle of the summer and it never got hot, kept pulling even though it was cooking outside. my buddy in his 4runner was going slower than me and he had to keep pulling over to let it cool down......... nuff said
oyah my truck is at 414k km's and counting
#33
Like I said in the beginning NOT this debate again lol
AZ...interesting you say "aside from the head-gasket recall"
That's the defining factor of the 3vz...the HG issues. I would be interested to learn WHY this is so. Was it a flaw in the block? Head? HG material? Surely the power and torque is better than the 22RE, but it sort of depends what the OP was asking.
I had a 94 3vz that ran like a champ until the HG blew around 200k. Now, I have a 22RE that blew the HG at 230k, but I have no history on both of those cars before I got ahold of them. I will tell you that when I bought my 86 4runner with the 22RE there was regular tap water mixed with the antifreeze. Who knows how long the PO ran in like that for, maybe its whole life?
#34
I guess it's just a matter of preference and personal experience, this debate has been beaten to death, and in the end no one on either side has changed their mind. In the end though, I think we all agree on one thing...
#35
The biggie is that it was originally designed for an asbestos head gasket. When asbestos was outlawed, Toyota had to rush to come up with an alternative, and, frankly, they screwed it up. They performed the recall, and replaced them with properly designed gaskets, and the reliability came back up to "normal" for an iron block/aluminum head engine designed in the early 80's.
IMHO, the recall is the big factor in public opinion - not the facts. People assume that since there was a recall, this must be the worst engine ever made. Simply not true. With the post-recall head gaskets, the 3.0 is every bit as reliable as the supposedly bulletproof 22RE.
91toyota is comparing a 4cyl truck to a V6 2nd gen 4Runner ... I wouldn't guess the extra 500-1000 lbs plays any part in the performance difference?
#36
theres too much heat build up around the #6 cylinder of the 3VZ...that's where about 90% of the HG issues are at...that cylinder.
Solution:
get rid of that P.O.S. stock cross-over pipe.
either get headers, or get a custom exhaust fabbed up (like i'm doing) to get rid of the crossover.
people will say the problem is because of the Iron Block and Aluminum heads..they have different tolerances to Heat...therefore they expand at different temperatures.
well hello!? almost every automaker has used an iron block and aluminum heads..and they didn't have HG problems?
it's the stupid stock cross-over.
that is all, thanks for reading
Solution:
#37
Chevy 350's..NEVER heard of one them having a headgasket issue...atleast not at large...maybe once or twice on the net...never heard about it in person..and pretty much everyone i interact with owns a chevy..and have always owned chevy's..and have never had headgasket issues.
#38
Good point about the crossover BTW. I don't necessarily agree that it's the primary cause, but it's certainly a hugely contributing factor.
#39
never said it was early 80's
my father has actually owned a few different chevy's with Iron blocks and aluminum heads..never had any problems...
but this is all just from one engine lol not really much of a comparison.
what other motors (of the era) were Iron Block and Aluminum head?
i'm pretty positive that my '96 dodge's 2001 360 motor has iron heads...but not positive.
#40
i said almost every automaker...without having info to back it up.
however i do believe the 5.0L 302 has aluminum heads...in that Era i mean.
i know Nissan was using aluminum heads, and i haven't heard of people having HG problems there.
Jeep uses Iron heads on the Inline 6..i know this because i rebuilt one...it's a heavy SOB
